Old 09-07-2007, 03:17 PM   #1
ceiling fan instal issue
I was trying to figure out where I went wrong.
I put a new ceiling fan in my house. I had a heater in the bathroom that wasn't working so I disconnected it's wire at the fuse box. I ran a new14-2 wire into the fuse box on a 20amp breaker. I ran it through the ceiling, cut my hole, hung the fan and attached the lower light fixture to the fan. Heres the problem, when I turn on the fan part, the low setting seems like it's high and the medium and high settings are way too fast. When I turn on the lights (3 of them) they all blow immediatly. I tried a new set of lights and the same thing happened. It seems like there is way too much electricity pushing through the fan. Is this right? How do I fix it?
Any help would be great.
mikpowl is offline   Reply With Quote
Old 09-08-2007, 01:02 PM   #2
Power Gen/RS Engineer
Was the existing heater 220V? Is the breaker single or double pole/handle? Assuming that you have wired the fan directly and are using the pull chains to control it, have you taken a voltage measurement at the fan?
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 09-08-2007, 02:03 PM   #3
" Euro " electrician
frenchelectrican's Avatar
the only way you can fix this mess is look at the fuse/ breaker box and how you got this hook up.
most heater useally i say useally are on 240 volt circuits and what i am thinking that you did retrace the same way as the old wire were ran before.
and if you ran the new wire in the fuse/breaker box find the white wire [ for the new circuit ] and move that to the netural bussbar that way you get a real 120 volt there instead of 240 volt
unforetally once you get this fixed IMO i think you will end up repalceing the ceiling fan as well again because some of control circuit in the fan itself can be fried [ i did see it happend once a while ]
Merci , Marc
Old 09-10-2007, 01:21 AM   #4
i would change out that 20 amp breaker to a 15 amp if you ran a 14-2 if you dont want to risk a fire. NEC 310.16 requires a 20 amp circuit to be wired in 12 awg wire.
gooch is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 11:50 PM
How would you fix this cosmetic ceiling issue? tinhouse General Discussion 6 08-24-2007 01:12 PM
