Ceiling Fan Hummmm - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2013, 08:49 PM   #1
Rewards Points: 50
Ceiling fan hummmm
After replacing my busted ceiling fan switch, rotary knob hi Med lo, with a rotary variable speed dial type, it now hums. Is this the nature of this type switch? Did not do this before.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-27-2013, 09:29 PM   #2
Electrical Contractor
kbsparky's Avatar
Yupp. Those infinite variable speed switches are basically glorified dimmers, which operate on sine-wave chopping. That results in a noticeable hum from the fan.
Go back to the 3- or 4-speed type and the hum will disappear.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
digitalplumber (07-27-2013)
Old 07-27-2013, 10:07 PM   #3
Rewards Points: 50
Thanks back to blowes tomorrow to exchange it!
Old 07-27-2013, 10:15 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Make sure you get the dehummer verison they will cost little more than conventail fan speed controller.
Then ya good to go ( keep the ceiling fan pull chain at high speed and control from the wall controller this is the best way and it will not generally make any humming noise at all.)
Merci,
Marc
Old 07-27-2013, 10:17 PM   #5
Rewards Points: 50
Merci,
Marc
Thanks that's how it was I thought it would be neat for the variable, but no. They only have one other the correct one maybe I should look elsewhere?
Old 07-27-2013, 10:31 PM   #6
Most of variable speed controller are useally are not dehummer verison and gernerally I just get a 4 speed contoller that useally work the best even on low speed setting it about perfect for most case.
The last dehummer variable fan speed controler I got from USA side was over 10 years back so I doubt if they still have it in big box store ou not.,
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 08-04-2013, 12:24 PM   #7
Rewards Points: 50
So I replaced with an Enerlites fan control switch, now my MED speed is too slow??? WTH!
Old 08-04-2013, 11:42 PM   #8
Did you any chance check the fan pull chain to make sure it is on high speed postion If so then something funky going on and can you post the model number of this controller this way I can try to figure it out what is going on with this one.
Merci,
Marc
Old 08-04-2013, 11:53 PM   #9
Rewards Points: 50
Merci,
Marc
Yes first thing I did.
Enerlites Fan Control Catalogue number 17003 120vac 60hz 2.5 amp
Some other numbers on switch:
YLFC700R
E313535
Old 08-05-2013, 12:13 AM   #10
YLFC700R
E313535
Give me a little bit I am digging this up right now as soon I find something I will let you know asap.
Merci,
Marc
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
