Ceiling Fan Help Needed Please-low Voltage? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 09:30 PM   #16
Thanks...if not consistant, how do I fix it? Anything I can do myself?
littlsht is offline   Reply With Quote
Old 04-04-2012, 09:38 PM   #17
I=E/R
a7ecorsair's Avatar
Start by verifying the voltage.
a7ecorsair is offline   Reply With Quote
Old 04-09-2012, 09:17 PM   #18
Update: Low voltage at ceiling fan
So, We borrowed a voltage meter and found 61-62 v across the white/black. The red wire has no exposed wire so there was no real way to test that without stripping, but obviously this has not been used even withthefan that used to work. So lately we have been opening all the outlets up to look for a red/white and black wires that were not connected to any switches. SO far, nothing. What's next? AND thanks in ADVANCE
Old 04-09-2012, 09:20 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Did you check voltage from hot to ground?
Old 04-09-2012, 09:25 PM   #20
Not yet...it should be 120 V, Correct ? Are we to test green or bare to black?
Old 04-09-2012, 09:27 PM   #21
k_buz's Avatar
Yes.
Is there an attic where you can go follow where the wire goes?
Old 04-11-2012, 08:22 PM   #22
Lightbulb
ceiling fan help needed please-low voltage? PROBLEM SOLVED!!!! Here's how!
Thank you are all the responses!! After no light or fan since November, buying two new remotes and a new fan, our old fan and remote are back up and working fine again! We ended up discovering a loose hot wire in a wall switch (it was the cheap kind that you just insert the 2 wires in the back). The switch was cracked as well. So we replaced the single wall switch ourselves, and viola-120v at the fan again.
For now: Lights on, blades turn, remote works-2 very happy girls sit and read posts to see if we can return any favors.
Old 04-12-2012, 04:42 AM   #23
dmxtothemax's Avatar
Rewards Points: 5,504
I thought it would be something like that.
good to know
thanks.
dmxtothemax is offline   Reply With Quote
Tags
ceiling fan , low voltage
Guidance needed with existing wiring - Ceiling fan install rickkrause2001 Electrical 4 03-23-2012 03:33 PM
Voltage Detector Affected by Snow? Arnold Ziffel Electrical 1 02-01-2012 09:56 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
ceiling joist size - 2x4 or 2x6 needed? bigdaddy352 Building & Construction 9 08-21-2007 12:02 AM
