-   -   Ceiling Fan and Existing 3 way Switch Wiring (http://www.diychatroom.com/f18/ceiling-fan-existing-3-way-switch-wiring-144051/)
brewtus32 05-17-2012 07:20 AM
I have a new ceiling fan and wiring that I ran in my living room. However, the 3 way switches are causing my some trouble. I can't get it wired correctly to my existing 3 way switches that control the top receptacle outlets around the room. The ceiling fan wire was run from the ceiling to a box that does not have the power from the breaker, it is run to the other 3 way switch. My preference would be to replace the 3 way switch with a 2 way and have it run the light kit on the fan and a 3 speed knob switch for the fan.
The first primary box that contains the black and white feed as well as a 14/3 cable with red, white and black.
The second box contains 14/3 a red, white and black as well as the 14/3 ceiling fan cable that has red, white and black. There is no hot from the breaker run to this box currently.
Let me know what questions you. Thanks in advance.
joed 05-17-2012 07:32 AM
Your post is confusing.
Where does the cable for the new fan run? What cable did you use? 14/3? 14/2?
How is the cable run between the switches and the power source and the switched receptacles? Do you want the receptacles to still be switched?
k_buz 05-17-2012 07:34 AM
If I'm reading your post correctly, you will not be able to do what you want to do.
You don't have a constant hot at the second 3 way switch location.
brewtus32 05-17-2012 11:08 AM
new fan cable runs to box 2 using 14/3.
i believe that there is a 14/3 wire run between the switches that also controls the outlets. I want at least one switch to still control the outlets but I am fine removing one of the 3 way switches.
brewtus32 05-17-2012 11:10 AM
--Is it possible to eliminate the 3 way switch(es), use a single pole in box 1 and use the 14/3 wire nut to the constant hot to send power from box 1 to box 2? I don't know how this would impact the switches.
k_buz 05-17-2012 11:33 AM
Probably not. Wiring wise it is possible and really, very easy, but eliminating that first three way switch would most likely violate code. You must have a way to turn on a light or outlet at the entrance to the room.
brewtus32 05-17-2012 11:36 AM
Thanks for your input. The first box would control the room lights and the second box would control the fan light. So both would provide a way to turn on the light at either of the 2 entrances to the room.
k_buz 05-17-2012 11:38 AM
I think we would need alot more information if we were to continue to try to figure this out.
How many switches are at each location?
What do they control?
What wires are in the boxes?
joed 05-17-2012 12:18 PM
I assume box2 is the second switch box and that it only has 14/3 plus your new 14/3.
If the power comes into other switch box or if the other switch box has a 14/3 cable to the receptacles then you can probably do as you wish. If not then you probably don't have a neutral wire in the switch so you will need to find a source of power for the new fan.
brewtus32 05-17-2012 12:27 PM
1 Attachment(s)
Here is a quick drawing to help explain visually.
k_buz 05-17-2012 12:37 PM
The diagram appears that you have mapped out what is actually there incorrectly. I see no way that this would work with only what you have listed on your diagram.
joed 05-17-2012 04:47 PM
There is no connection shown to the receptacles that are switched. Your cable labeled to breaker most likely actually goes to the receptacles. You can not do what you want without changing that cable to a 14/3. You have what is called a switch loop.
