Ceiling Fan Downrod Adapter - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 11:45 AM   #1
Cool
Ceiling fan downrod adapter
I'm replacing a failed Hunter ceiling fan with another fan that was given to me. The Hunter had a 3/4" down rod with a threaded end which went into a threaded female fitting on the fan. My new fan has a 1/2" threaded male stud coming out of the top of the fan. Unfortunately, the new fan has no brand name or model number on it. Does anybody know of a 3/4" to 1/2" threaded female adapter that would enable me to connect the two?
Chaarles124 is offline   Reply With Quote
Old 10-10-2011, 12:40 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
1/2 by 3/4 " plumbing coupling should work. I would drill thru each end and install a cotter pin.
Coastal South Carolina
Old 10-10-2011, 12:56 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any "down-rods" I have ever installed had a "ball and socket" assembly. The socket mounted to the box and the ball mounted to the end of the rod and simply hung in the socket so that it could freely move about (within limits of course).
XXX
Old 10-10-2011, 01:29 PM   #4
A "Handy Husband"
rjniles's Avatar
Bud,
I took it that the OP was adapting the existing 3/4" downrod to a new fan that was set up for an older fan that had a 1/2" downrod stud on top of the fan. The ball and socket at the ceiling bos is the existing setup from the old Hunter fan.
Old 10-10-2011, 01:34 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe Hunter was all I ever came in contact with. I haven't touched a ceiling fan (other than to turn mine on and off) in years.
I also remember the name Casablanca. Was that a Hunter fan maybe?
XXX
Old 07-07-2012, 10:41 AM   #6
Lowes sells a downrod adapter that goes from a 1/2" fan fitting to a 3/4" downrod. Comes with all the expected set screws and pins for safety.
joehuber is offline   Reply With Quote
Tags
adapter , ceiling fan downrod , converter , reducer
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling Fan Downrod Length kennykenny Electrical 6 04-18-2011 10:02 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 10:20 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
