Ceiling Fan Broke??? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 01:21 PM   #1
I have power going to the ceiling fan and when I turn the switch off, there is no power. So the motor is getting power but does not come on, my mom was looking online and thinks it might be the capacitor on the side of the motor. I pulled it and its an aerovox 15uf 330v 60hz 70c.
I cannot find a replacement online or at lowes or ace hardware. I dont even think those stores carry capacitors.
Can anyone help me find a replacement so I dont have to go buy a new fan motor for nothing.??
Thx for reading.
Josh
jmrivers2006 is offline   Reply With Quote
Old 05-28-2009, 01:36 PM   #2
Don't just start replacing parts and don't assume anything.
1. Make sure the reversing switch it not stuck in the middle. Make sure the fan speed switch isn't in the ioff position.
2. Test for voltage at the fan ceiling j box. You should have appx 120 volts hot to neutral (black to white).
3. If you hvae proper voltage, you need to follow it and test it. The power goes into the fan speed pull switch and out 3 times to hi, med and low. Follow the circuit and find the bad component (if possible).
Remember that electricity can and will kill you. It is sitting in the wires, silently stalking you just waiting for a chance to strike.
Is your life worth a $50 ceiling fan?
220/221 is offline   Reply With Quote
Old 05-28-2009, 03:48 PM   #3
I just realized- Its a house exhaust fan, not a ceiling fan...sorry for confusion, and I just found out that the house fan came from Sears, and they discontinued the capacitor I need...doh, thats why I couldnt find it.
Old 05-28-2009, 08:19 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Find a motor shop and you will be able to find a cap to match what you need.
Old 05-29-2009, 07:54 AM   #5
good call...now I just have to find one. What about a heating and cooling service, think they would have one?
Old 05-29-2009, 08:05 AM   #6
Say it Is not so!!!!
The Cap. could be the problem...........
Is that a "Start Cap." or a "Run Cap."?
Lookie Here:
http://www.illinoiscapacitor.com/
http://www.electricmotorshop.net/
Or
APEX Supply
Grainger
MALCO.New.York is offline   Reply With Quote
Old 05-29-2009, 08:07 AM   #7
electrician
Newark
Silk is offline   Reply With Quote
Old 05-29-2009, 08:09 AM   #8
I think Silk means these guys:
http://www.newark.com/
Old 05-30-2009, 11:47 AM   #9
Rewards Points: 204
I agree with the poster regarding a motor shop. They have the caps and can match it up to your motor. However, you don't know if it's the cap. Take the motor out and take it in.
Where are you. I can hook you up with an EASA shop near you.
Old 06-02-2009, 01:27 AM   #10
Um..it would be much easier to spend 10 dollars on a new cap than tear the motor down. If that doesnt fix it then it will have to come down.
I'll try to look for a motor shop, and I'll try all of the web links provided, thx all, lots of help.
Tags
capacitor , ceiling , ceiling fan , fan
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
