Ceiling Fan Bracket Killing Power In A Very Weird Way. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 06:00 PM   #1
The Carpenta!!!
ManMythLegend's Avatar
Ceiling fan bracket killing power in a very weird way.
I'm installing a ceiling fan in an old house I'm renovating. The wire in the ceiling box is greenfield. I killed the power to the box at the light switch. I know I'm supposed to kill the power at the breaker so I don't need anyone to tell me how unsafe I am. I already know. Anyway, everything was good I tested for voltage with 2 different testers and nothing. Zero current. I started to screw the new bracket to the box and it made contact with the white wire, arched, and tripped the breaker.
I'm no electrician, but if the voltage reads zero should this thing arch?
I WILL PERSIST UNTIL I SUCCEED.
I AM A LION AND I REFUSE TO TALK, TO WALK, TO SLEEP WITH THE SHEEP.
THE SLAUGHTERHOUSE OF FAILURE IS NOT MY DESTINY.
ManMythLegend is offline   Reply With Quote
Old 10-27-2008, 06:07 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
3-way switch?
Do any wires junction in the box?
How many wires are in the box and what colors? Did you test all the wires to ground?
I wonder if they switched the neutral and you tested the hot leg to the neutral leg that was switched off, so you didn't get a reading. Then you touched the hot and were grounded. I bet this is what happened. You need to look at the switch, and test for power to a verfied ground - i.e. extension cord with a known good ground. If your not entirely comfortable with this, then you should get some help, especially since my guess is that your not using insulated tools.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-27-2008, 06:07 PM   #3
joed's Avatar
Rewards Points: 13,752
It depends what you were comparing it to. You can't read zero on one wire. You need two points. You must not have used the proper two points.
Old 10-27-2008, 06:17 PM   #4
The Carpenta!!!
There are only 2 sets of wires in the box, blacks and whites, and all the whites are twisted together. One tester was the kind with 2 leads and it tells what the voltage is with a light the other tester was a "no contact" tester so I don't really know how I could be messing up the test.
When I go back to the house tomorrow I'll count the wires, take some pics, and write a short description. Thanks for the quick reply and your help fellas.
Old 10-27-2008, 06:29 PM   #5
DIY'er
jamiedolan's Avatar
Do you understand what I mean about using an extension cord to test to with the ground on it?
Jamie
Old 10-27-2008, 06:53 PM   #6
You could have a neutral shared with another circuit.
Matsukaze is offline   Reply With Quote
Old 10-27-2008, 06:59 PM   #7
DIYer
It's a long shot, but make sure your neutral and ground are bonded together correctly at your main panel. You could have a serious problem if you are arcing neutral to ground.
Gigs is offline   Reply With Quote
Old 10-27-2008, 07:01 PM   #8
not offering electrical advise, had similar problem changing an outlet, with the breaker off, got power off the neutral, as explained to me, it could of been caused by the neutral sharing with anothter neutral.
DUDE! is offline   Reply With Quote
Old 10-27-2008, 08:21 PM   #9
The breaker wouldn't trip if it was a neutral, it has to have been hot.
rgsgww is offline   Reply With Quote
Old 10-27-2008, 09:14 PM   #10
Pull out the switch and tell us what wires are in there.
I suspect two
If there are two wires in the sw box, the power is in the light box. It is then sent down to the sw and then back to the light.
Disconnect all wires and tesy voltage from black to white #1, Black to white #2. Then test everything one at a time to ground (ground wire or metal box)
220/221 is offline   Reply With Quote
Old 10-27-2008, 10:21 PM   #11
Rewards Points: 2,350
I suspect two
As do I.
Old 10-28-2008, 11:32 AM   #12
Rewards Points: 246
Jamie
The fan will run just fine without the ground, and testing to ground is not a good idea, and can and will give inconsistent readings. Test between the circuit conductors, (white & black) not to ground.
This extension cord thing is dangerous and should not be attempted by anyone, including electricians.
Edit.....I have no idea what this method is. So, I retract the statement until I find out what it is and how it is performed.
Old 10-28-2008, 11:38 AM   #13
Originally Posted by J. V. View Post
The fan will run just fine without the ground, and testing to ground is not a good idea, and can and will give inconsistent readings. Test between the circuit conductors, (white & black) not to ground. This extension cord thing is dangerous and should not be attempted by anyone, including electricians.
I disagree. If the ground is good, ground is a fine test point. How, exactly, is the extension cord test dangerous?
Old 10-28-2008, 12:22 PM   #14
Licensed Pro
The extension cord test is a tried and true technique for determining which wire is hot or neutral when colors are obscured or there is no true ground present. I don't see why it would be considered dangerous.
Old 10-28-2008, 12:33 PM   #15
Rewards Points: 246
IMO testing to ground is not always a good indicator. As you point out "if the ground is good"? What if it's not. The point being the fan does not need a ground to operate, so why test to ground when the circuit neutral is present.
I really do not understand what you guys mean by the extension cord method. If you could clarify what this method is, I will be more than happy to retract my statement.......Thanks John
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Bring power to Ceiling Fan HELP mechcross Electrical 1 08-24-2008 05:45 PM
ceiling light power loss pejay Electrical 4 08-22-2008 05:02 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
Bracket to Ceiling mount a Wall mount floodlight Ski Electrical 1 06-27-2008 11:18 AM
