Ceiling Fan Blues..
Please explain how you wired the fan and light dome. Generally you have four wires a fan motor wire (black), a light wire (blue) a neutral (white) and a ground wire. Explain how you connected the wiring in the box to the ceiling fan wires.
Is the fan a pull chain operated fan or is it operated from switches on the wall or both?
Is it a fan with a remote?
Also if your installing at an existing ceiling box and it is not ceiling fan rated you run the risk of the fan weight pulling the box from the ceiling.
Stubbie
