Ceiling Fan Ans Light Works Erratic - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 08:41 AM   #1
Question
Ceiling fan ans light works erratic
My ceiling fan and light work fine in the evening but does not work in the morning. The trouble started 15 days ago. I checked all connections and found them to be ok. Please help me. Thanks.
Vipan Wadhera is offline   Reply With Quote
Old 07-12-2012, 12:21 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Are you having any other problems anywhere else in the house?
Has anyone added a timer in the circuit somewhere?
Was any work done 15 days ago?
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Evstarr (07-12-2012)
Old 07-13-2012, 11:57 AM   #3
Ceiling fan and light works erratic
Thanks for the response.
No other problem any where in the house.
no timer has been added in the circuit either.
No work has been done for over a year and not any electrical work for over many years.
Old 07-13-2012, 12:12 PM   #4
Licensed electrician
Rewards Points: 1,266
I suspect you still have a loose connection that you have not found. It could be anywhere in the circuit.
Old 07-13-2012, 03:25 PM   #5
Thank you for your time.
I sincerely appreciate your help.
Old 07-14-2012, 03:01 PM   #6
Are they on a wall switch or ceiling pulls? Could there be a switch somewhere that covers this hot line? Maybe a 3way thats lost a traveler?
Evstarr is offline   Reply With Quote
Old 07-14-2012, 03:19 PM   #7
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The fan and the light. Evening and morning. Are they on separate switches? I would start with the connections inside the fan box. Take the wire nuts off and put them back on.
John
jrclen is offline   Reply With Quote
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 06:46 AM
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 11:04 PM
Help!! for installation of a hanging light from a drop ceiling Marilee516 Electrical 3 12-04-2011 03:46 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 09:14 AM
