Ceiling Fan Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 01:49 PM   #1
Rewards Points: 109
Ceiling fan addition
Can I add a ceiling fan which is "hardwired" and is only controller via a remote control switch? Seems like it would be a yes, just want to make sure.
BimmerRacer is offline   Reply With Quote
Old 06-11-2012, 07:58 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Based on the information you provided, yes. If there is a ceiling box controlled by a switch, just make sure the switch is on or the remote won't work.
JulieMor is offline   Reply With Quote
Old 06-11-2012, 12:56 PM   #3
Rewards Points: 109
Nope, no switch. Just ran the wire yesterday from last outlet to the J Box.
Old 06-12-2012, 05:59 PM   #4
Corroded-Mind's Avatar
I have a similar question/ situation. About a month ago I installed ceiling fan as well, but I had the light switch already on the wall. One morning I turned off the fan via the light switch just like I had done before, and now it won't turn on. So uninstalled the ceiling fan and swapped it out for a new one, and still nothing. All the outlets in the room are currently work, where do I begin on trying to diagnose the problem.
Corroded-Mind is offline   Reply With Quote
Old 06-12-2012, 06:27 PM   #5
Licensed electrician
Rewards Points: 1,258
You are going to need to see where you have lost the power.
Old 06-13-2012, 06:23 PM   #6
Well I started with the switch and viola it was the switch that went bad, not the ceiling fan.
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 08:52 PM
Another 2x6 cathedral ceiling juststarted Building & Construction 17 11-22-2011 05:27 PM
Ceiling joist Redbeard58 Building & Construction 3 07-03-2011 09:09 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
