Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 12:20 AM   #1
Ceiling Fan
I have a wall switch wired to a ceiling fan with a light. I want to put a dimmer (plain rheostat) in for the light. when reading the fan manual it said specifically NOT to use a dimmer with the fan, though i could use one with the light. and it explains the leads coming out of the fan. my problem is that the cable between the fan and the switch is only two wire + ground.
i guess my real question is how could i pull cable through so that i could hardwire the fan so it's controlled by the pull switch on the fan and the new dimmer controls the light.
Koolone0 is offline   Reply With Quote
Old 10-13-2010, 07:39 AM   #2
Licensed electrician
Rewards Points: 1,864
You would need to pull a new cable between the fan box and the switch box. If you have access from the attic above this area it is fairly easy. If the above is finished you will need to do some cutting and patching of drywall.
When you say only two wires do you mean a black and a white are on the switch?
Old 10-13-2010, 05:34 PM   #3
yes, you will have to rerun a new wire.. pick up a 3 wire romex, it will have a black/white/red/ground in it.
ibjames is offline   Reply With Quote
Old 10-13-2010, 09:06 PM   #4
Electrical Contractor
kbsparky's Avatar
Sheesh, guys!! NO YOU DON'T HAVE TO INSTALL ANY MORE WIRES!!!
Simply install a fan remote kit, which only requires 2 wires for its power. A canopy mounted receiver separates the fan from the light, where you can now dim the lights, as well as control the fan speeds.
Click here for one example
-KB
Old 10-14-2010, 12:38 AM   #5
true, but the pricetag is a bit higher than doing it the other way. though i might look into that if my wiring isnt eaily accesible through the ceiling. also, i lose small things like remotes >.<
Old 10-14-2010, 01:01 AM   #6
the circuit would be something like this? i know its not too pretty
Old 10-14-2010, 06:21 AM   #7
jbfan's Avatar
Rewards Points: 648
That looks good, but if you are going to all the trouble, add a wall switch for the fan also!
jbfan is online now   Reply With Quote
Old 10-14-2010, 06:59 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Here is a remote for $22 - as cheap as the coil of 3 wire cable you will have to buy.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
OR $50 for a unit that is mounted in the switch box - no remote to mislay,
Coastal South Carolina
Old 10-14-2010, 08:19 AM   #9
well, part of this is that i want to do some of this kind of stuff (pulling new wires and installing new outlets etc) because my dad is deathly afraid of electricity and i kinda wanna show him its not all that difficult even to install your self
and i might be trying to change some outlets over to three prong from polarized two prong.
@ jb the fan has the pull on it and i only want it to have one thing to control it, not a wall switch and the pull selector. but not a bad idea if i wasnt going for one controller
Old 10-14-2010, 09:26 AM   #10
A "Handy Husband"
rjniles's Avatar
If you use one of the suggested remotes you will have complete control of the fan speed and be able to dim the light in addition to turning on/off - all from the remote. You can cut the chains off the fan switches (not that I recommend that).
But if you want to practice wiring - do your thing- but make sure you know what you are doing. Replacing 2 wire receptacles with 3 wire a can be quite a first timers task. It not just a matter of changing the receptacle.
Old 10-14-2010, 10:25 AM   #11
well, based on how easy the access is in my ceiling i may decide to drop another cable down as well and put in a companion dimmer on the other side of the room.
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
