Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 07:05 PM   #1
ceiling fan
the lightswitch controls an outlet. there is one black and one white wire coming into the switch box on the wall. i want to replace the single switch with a double switch and have one switch give power to the outlet (as was before i started this whole thing) and the other switch give power to the ceiling fan. i will work the cords of the fan separately and just want power to the fan and light from one switch. i need a digram of how to attach the wires currently coming into the switch box and the new wires (12-2, white black and ground) i've attached to the fan and brought into the existingswitch box.
danrxman is offline   Reply With Quote
Old 08-28-2010, 07:24 PM   #2
Licensed electrician
Rewards Points: 1,622
You do not have a neutral in your switch box. You have a constant hot and a switched hot. You will need to get power from another box in order to power your fan.
If you do not want the receptacle switched you can use the switch box as a source of power if you make some changes to the receptacle wiring.
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
