Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 05:41 PM   #1
ceiling fan
I hooked up ceiling fan, light works, fan doesn't?
rbet2 is offline   Reply With Quote
Old 08-15-2010, 05:47 PM   #2
Electrician
Proby's Avatar
Did you connect both the black and blue wire from the fan to the black wire coming out of the box?
Did you pull the chain?
Is there a remote kit with this fan?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-15-2010, 08:19 PM   #3
Electrical Contractor
kbsparky's Avatar
Check the reverse switch on the fan. If it's placed in the middle, the fan won't operate.
-KB
Old 08-15-2010, 08:20 PM   #4
Electrician
Proby's Avatar
Wow, that brings back memories.
Old 08-16-2010, 07:09 AM   #5
Hi, rbe2 ceiling fan doesn't work, sorry to hear this. All the previous post to you were very good.
Here how I do it. Before installing a ceiling fan with or without light kit, I light to assembly to unit first, then take an
a male power cord, with the female cut off. Than following the direction supplied with the kit, I connect the wires to
see if indeed this will work, before I climb up a ladder an install it.
Good luck.
Ranger31 is offline   Reply With Quote
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
