Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 12:56 PM   #1
ceiling fan
I had a ceiling fan installed, actually I had 2 fans installed. I have a remote control on one. The fan goes on by itself every so often. I can shut it down with the remote . I was wondering if he didn't install it right. The other one makes a clicking sound. I don't use it for fear of a fire. HELP
hed ruggiero is offline   Reply With Quote
Old 05-24-2009, 12:59 PM   #2
the Musigician
DangerMouse's Avatar
does the remote allow timer setup? if so, turn it off. if the clicking on the second one is electrical sounding, call the guy back, if it's more of a scraping sound, it's likely off balance, call the guy back or try to level it yourself.
DM
Old 05-24-2009, 12:59 PM   #3
the Musigician
oh, and hi and welcome to the forum! ( i forgot)
DM
Old 05-24-2009, 01:37 PM   #4
Did you/he set the dip switches to different configurations? If not, one remote may/will turn on both fans.
The clicking noise could be many different things including loose screws or mfg defect.
Call the guy who installed them.
220/221 is offline   Reply With Quote
Old 05-24-2009, 01:51 PM   #5
300zx's Avatar
Fan
Is the other fan a hugger-If so check make sure wires are tucked in box and not hitting moter when spinning. The other check dip switchs maybe another remote like tv or something is your problem.
300zx is offline   Reply With Quote
Old 05-24-2009, 02:01 PM   #6
Rewards Points: 64
Check and change the dip switch settings. I had someone with the same problem. The next door neighbors garage door opener turned on their fan, they said. Changed the dip switch settings and corrected the problem. It's common.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
