Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2004, 04:38 PM   #1
RogerB's Avatar
Ceiling Fan
On a scale of 1 - 10 -- how hard is it to install a ceiling fan? I would like to install one outside on my porch. Any special considerations? -THANKS
RogerB is offline   Reply With Quote
Old 01-19-2004, 10:00 PM   #2
Guest
Guest
Posts: n/a
If you already have a light out there it is about a 3. If you don't bump it up to 5 or 7 depending on how experienced you are.
Old 01-20-2004, 09:25 PM   #3
Guest
Guest
Posts: n/a
Code wise you are required to use a fan-rated electrical box. Use a fan made for the damp/wet area. Could mean additional wiring to have separate switches for fan and light. Never use a lighting dimmer as a speed control for a fan. Use a fan speed control. When in doubt, hire a pro. Unless your buddy or brother-in-law really IS an electrician, don't let him wire anything.
Old 02-27-2006, 07:17 PM   #4
Depending on what you are mounting the fan to, it is very easy, or quite difficult. The problem lies if there isnt already proper wiring and support for a fan, then you have install a brace and/or wiring, etc. If there is already box there that can safely hold a fan, go for it!
For more information on installing ceiling fans:
http://www.ceiling-fans-n-more.com/c...stallation.php
ceilingfanrepair is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
ceiling fan downrod extension installation smallcrpt Electrical 3 02-12-2007 03:14 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
