Ceiling Fan 3rd Pull Chain - Electrical - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 01:22 AM   #1
starkenwolf's Avatar
ceiling fan 3rd pull chain
This is crazy, as I've installed about a hundred ceiling fans in my day, but......what is the function of the 3rd pull chain on the Hampton Bay I just installed?\r\nIt isn't the directional control as the fan has the traditional switch for this.
The only thing I can figure is it's a means to control the fan and light with one pull chain. The generic instruction book doesn't address it.
Thanks for your help!
starkenwolf is offline   Reply With Quote
Old 12-16-2010, 04:13 PM   #2
Chewy - Lic. Electrician
Sometimes the fan comes factory with no light, they will sometimes throw in a pull chain to control the wires that would have been for the light, then when you get a light to put in it will have a pullchain on it for the off chance there is no pullchain to control it on the fan fixture itself. or it could be the reversal switch for the direction of the fan.
SGC622 is offline   Reply With Quote
The Following User Says Thank You to SGC622 For This Useful Post:
starkenwolf (12-18-2010)
Old 12-16-2010, 07:47 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Some of the ceiling fans I have see with third pull chain that useally resverd for the revering switch so it can run the fan foward or reverse.
Due some case the housing or design prevent to use the conventianl switch they used the pull chain to do this function.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 12-18-2010, 01:40 AM   #4
Well....sorted it out. As it happens, there's a 3rd light (an upper tier light) in the upper canopy of the fan. When lit, the light shines through the venting in the side of the fan motor....kind of a night light.
It is not even mentioned in the instructions or on the packaging.
Would have been easier to figure out but for the wiring harness for the light kit was defective. I ended up cutting the light feed out of the harness and splicing it directly to the light kit. Voila! Works like a charm.
Who knew there was a night light? The homeowner was very proud of his purchase.....wait until he has to change the bulbs in it....3 screws per light access, 4 bulbs....accessed from the top of the fan motor assembly.
Thanks for your help guys!
The Following User Says Thank You to starkenwolf For This Useful Post:
frenchelectrican (12-18-2010)
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
how do I gang wire two fluorescent fixtures with a pull chain switch bigjer Electrical 1 06-21-2010 12:25 AM
shop light conversion from pull chain to light switch gilbo Electrical 6 03-16-2010 10:49 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
