Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 05:29 PM   #1
Ceiling fan
I am wiring in a ceiling fan to a 2 switch wall switch, incoming wiring has black, white, ground. Out to wall socket has black, white, red, and ground. I have run black incoming to black to wall switch, light wire(blue) from ceiling fan to red to wall switch, white wire from ceiling fan to white incoming, black wire(fan motor wire) to white outgoing to wall socket. Here's what's driving me crazy, in the wall socket there is another set of wires going to my kitchen lights, (black, white, and ground). How do I send power to the kichent light? Any help would be greatly appreciated. Thanks.
snowcam is offline   Reply With Quote
Old 11-11-2012, 07:44 PM   #2
Any chance of a simple drawing of what wire goes were hard to follow just from reading
wallajon is offline   Reply With Quote
The Following User Says Thank You to wallajon For This Useful Post:
snowcam (11-13-2012)
Old 11-11-2012, 10:48 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You have a switch box and a wall socket and a ceiling fan. Did you install the switch box with the two switches, the wall socket and ceiling fan or were the switches already present. I suppose I'm not understanding where the wall socket comes into play. This is a typical drawing that is close to what you discribe.
The Following User Says Thank You to Stubbie For This Useful Post:
Old 11-12-2012, 10:11 AM   #4
wiring puzzle
Hopfully this picture comes through. It will show you where I am with this.
Thanks again.
The problem I have is that I have a couple of kitchen light switches wired after the ceiling fan switches. I can wire the fan motor and ceiling fan light, but I'm not sure how to get power to the kitchen lights wired downstream from the ceiling fan switches. Any info would really help. Thanks.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
