#1 |
ceiling fan
I would love to put a ceiling fan in my living room but my husband isn't anxious about climbing into the attic to anchor it. He's not really that handy. I was wondering if a fan could be hung like light fixture, by a chain. Obviously, the ceiling would have to have a joist to put the hook into so the fan could hang. The chain and cord would be loosely hung near outlet so it could be plugged in.
#2 |
Electrical Contractor
ceiling fan
Those things are hung from solid pipes for a reason. A fan hung from a chain would not be a feasible solution.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
ceiling fan
Lowe's sell an indoor/outdoor fan that can be hung from an eyehook in the ceiling. It is also plug in. It is item number 5880.
The reviews on it are mixed. I think a lot of it is that a 20 inch fan will never perform like a 52 inch. Those expecting airflow similar to a large fan are bound to be disappointed. But even with it, if I needed more drop, I would get a longer downrod for it, I would not use chain. |
#4 |
Master Electrician
ceiling fan
if you want to see your fan swing in circles a chain would be a great idea. oscillating function without the oscillating price.
Sarcasm is my friend I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own. |
#5 | |
"So I Re-Wired It"
ceiling fanQuote:
![]() NEC 314.27(c) "Outletboxes or outletboxsystems used as the solesupport ofaceiling-suspended(paddle)fanshallbelisted,shallbe markedbytheirmanufacturerassuitableforthispurpose, andshallnotsupportceiling-suspended(paddle)fansthat weighmorethan32kg(70lb)" In other words, a ceiling fan must be properly secured to a fan rated box.
Knowledge is Power, but 240v can Keel You!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
ceiling fan
It is not always necessary to climb into the attic to support a fan box. But is usually the best way.
This type of fan box is designed where you can do everything from underneath. I have never used one, so I cannot comment on how well this works. |
#7 |
ceiling fan
Chain, no.
fan rated box, yes. I have done a few add on fans and have never had to climb into the ceiling. fan support boxes are made for all the work to be done below. They are not a piece of cake but are doable. This is not really a job for someone that is "not really handy". Do not be tempted to just hang the fan from the existing box. it may work for awhile, but will eventually come down. |
#8 |
E2 Electrician
ceiling fan
fan on a chain would be cool... sorta like an indoor kite flying around. lol...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#9 | |
" Euro " electrician
ceiling fanQuote:
I did bolted out of that place due that guy did ran a big arse Hunter fan on chain. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#10 |
ceiling fan
Thank you all for your input. I actually knew someone that screwed the hook into a ceiling joist but never heard how it actually worked out. I will hang on to your suggestions and check into doing each one of them. Thanks again, I appreciate it.
| Display Modes | |
| Ceiling Joist Size | russ_mc | Building & Construction | 7 | 02-24-2012 05:06 PM |
| Popcorn ceiling with asbestos - options? | 30Five | Drywall & Plaster | 6 | 02-21-2012 10:27 PM |
| Paint peeling off Bathroom Ceiling!!! | armen30 | Painting | 17 | 12-08-2011 09:26 AM |
| Level 5 finish expectations? Cracked ceiling.....input needed please! | HeatherJ | Drywall & Plaster | 6 | 01-14-2011 06:04 PM |
| Pot lights in a drop ceiling | Howdy | Electrical | 3 | 03-14-2008 09:23 PM |
