Old 11-17-2007, 10:58 PM   #1
jelly's Avatar
Ceiling Fan 14/3 or 14/2?
Ive searched all around but I never found a definitive answer to my question.
I am installing a new ceiling fan. I will not be using the light fixture included, does this mean that I do not need the 14/3 wiring?
14/3 is only if I choose to hook up the light fixture on the fan?
One other question, is 14/2 feed good enough? When would I want to feed with 14/3?
Thx
jelly is offline   Reply With Quote
Old 11-17-2007, 11:05 PM   #2
14-2 should be fine for what you are using it for just a fan.
As a general rule i usually always run 14-3 for fans just incase you wanna put a light kit on it laterand have a seperate switch for the fan and light. However you can still get a light kit on a fan using 14-2, but you will be using pull chains. Another option that is available for 14-2 wiring is a remote control device. you install a reciever inside the fan box which also will allow you to operate fan/light seperately from the remote
RichyL is offline   Reply With Quote
Old 11-18-2007, 01:43 AM   #3
ALWAYS use 3 wire for a fan. Even though YOU dont want a light the next guy might. You (or the next guy) also may want to add some recessed cans at a later date and you will already have the switch leg in the ceiling.
It's not much more expensive.
220/221 is offline   Reply With Quote
Old 11-18-2007, 06:33 AM   #4
jelly's Avatar
Thanks. Surrounding the fan is recessed lighting which will be controlled by two 3 way switches. (this is why I wont be using the light fixture) Good idea to run the 14/3 anyway.
This fan was hooked up when I bought the house, why would someone run 14/3 directly out of the panel box to the fan wall switch? Could it simply be that they ran out of 14/2 and just had extra 14/3?
Old 11-18-2007, 07:30 AM   #5
Electrician philosopher
Could be a multiwire branch circuit. Are all the wires hooked up in the switch box?
Or he could have been out of wire like you said. Been there done that.
Andy in ATL is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
What type of ceiling should I use? dzimmer88 Remodeling 2 09-25-2007 04:18 PM
