Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 05:04 PM   #1
ceiling fan
Hello ,
I installed a Hampton Bay Metarie ceiling fan,
my problem is the light works fine the fan will not work,
there are 2 wires coming from the ceiling box white and black,
i connected the blue and black from the kit to the black wire from ceiling,
and the white to white.
can someone please help me out i live in a older home, should i move the black wire from fan and connect it to the ceiling white wire. ?????
jake2012 is offline   Reply With Quote
Old 02-04-2012, 05:08 PM   #2
Rewards Points: 2,516
just double check your connections under the wire nut....sounds like the black wire(from the fan) may not be making contact under the wire nut.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
jake2012 (02-04-2012)
Old 02-04-2012, 05:12 PM   #3
Rewards Points: 13,748
Connect it to the white and you just made a dead short.
Blue and all the blacks together should work.
Should have them all twisted together then install the wire nut.
Old 02-04-2012, 05:19 PM   #4
thank you,
very much i will try that.
Old 02-04-2012, 05:19 PM   #5
Thank you
very much i will try it.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
