Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 05:32 PM   #1
ceiling fan
I have a ceiling fan I am replacing. It has a wall switch (on-0ff). From the box there are two black wires, two white wires and ground. I hooked up the black and blue wires from fan to the two blacks from box, the white from fan to the two whites and ground to ground. If the wall switch is off, it throws breaker when I turn on. If the switch is on it will work when I switch the breaker but blows the breaker when I turn it off at wall switch. Obviously I have a wire in the wrong place. Any help appreciated
bclarke is offline   Reply With Quote
Old 11-12-2011, 06:38 PM   #2
Rewards Points: 1,666
I guess you didn't check what went where with the old fan before you took it down? (learning lesson).
Do you own a cheap 120 volt test light or multimeter?
What colors are the wires on your wall switch? How are the wires by color connected in the switch box?
You may have a switch loop and one of the whites at the fan end of things may actually be a black (hot) line.
bob22 is offline   Reply With Quote
Old 11-12-2011, 06:59 PM   #3
Rewards Points: 582
sounds like your switch is powered down from box..would need pics....but my guess split 2-white wires....one is switch leg...hot from switch...need to check with meter...black,blue from fan to switch leg? other white neturel to white to fan ..ground to ground... should work.....try it may have to due it 2 times if you don't have tester....
Old 11-12-2011, 09:08 PM   #4
Rewards Points: 508
The 'fan' might actually be a fan/light combo.
Possibility 1: If you are installing unit as a fan only, don't use the blue wire. It's likely for the light kit. Try 1 black / 1 white at a time etc but looking at switch wires at the switch should cut down on the guessing. If for fan and light on one switch, the blue goes with one of the blacks but try the other one.
Possibility 2: Your original switch area has 2 switches. One for fan, one for light. black/black white/white and black/blue white/white but figuring out which is which takes time.
diyorpay is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
