Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 12:43 PM   #1
Ceiling Fan
I just finished hanging a new Hunter Waldon Ceiling fan with light kit. This is our third identical installation in 2 weeks but this one has an issue. When I turn the single pole light switch on the light comes on but the fan will not. We have checked the breaker, and moved the reverse switch and pulled the fan chain multiple times. Any thoughts before I have to return this one back to Lowes?
Leland is offline   Reply With Quote
Old 08-16-2011, 12:48 PM   #2
Code05's Avatar
Rewards Points: 1,104
Did you check the connection at the box and make sure the fan is connected to the hot wire good in the wirenut?
Code05 is offline   Reply With Quote
Old 08-16-2011, 12:49 PM   #3
the Musigician
DangerMouse's Avatar
If you've verified a proper install, then you know the answer.
Check one last time at the wiring job, then take it down and return it, since it's dead out of the box.
It happens....
DM
Old 08-16-2011, 01:08 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
There should be two wires connects to the incoming black. One for the light and one for the light. There should also be two whites connected to the neutral. After that return it. DOA.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2011, 01:43 PM   #5
Master Electrician
Rewards Points: 3,870
Most, if not all ceiling fans only have one white wire to connect to the incoming neutral.
brric is online now   Reply With Quote
Old 08-16-2011, 02:10 PM   #6
Rewards Points: 6,652
My guess is incorrectly hooked up. Someone either left the wire for the fan hanging loose, or there is a possibility that there is 14/3 coming into the junction box, and they thought that the red was hot, and hooked the fan to that, and no voltage. My mother in law had a ceiling fan, that you had a switch leg going up to it the junction box, but when you looked at the box, you had a power leg, and another leg for power, that when they first hooked it up, it was all jacked up, and not working on the fan side.
Old 08-16-2011, 03:42 PM   #7
electures's Avatar
SOmewhere inside the fan the neutral from the light and the fan are probabely pigtailed and the single wire is ran upto the jb. I am thinking one of the wires came out of the wirenut. The OP will have to drop the light kit to check.
Old 08-16-2011, 03:48 PM   #8
Code05's Avatar
I am betting that fan wire is not connected well. A lot of people will also over twist and break the small wires.
The Following User Says Thank You to Code05 For This Useful Post:
gregzoll (08-16-2011)
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
