Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 08:47 PM   #1
Ceiling fan
Hello all my name is Jon and I have a problem with my ceiling fan/light which is located upstairs in the master bedroom. The unit is 4-5 years old and the house we live in is only six years old. So the issue is the remote became sketchy at times but manually it would work fine then it up and quit working altogether. There is power to the room because all the other outlets work fine and I've tried shutting off the breakers for all of the upstairs and left it off for 5-8 minutes and flipped it back on but still didn't fix the problem. Also we've smelt no burning either. Thanks for any help that can come our way.
Jonny3777 is offline   Reply With Quote
Old 06-04-2011, 09:14 PM   #2
Rewards Points: 6,652
Most likely the battery is dead in the remote, and needs to be changed. Batteries only work so long, especially if you use the device continuously to change the fan settings.
Old 06-04-2011, 09:54 PM   #3
Well it still lights up but even without the remote it doesn't doesn't work manually by pulling the cord for the fan and the light.
Old 06-05-2011, 07:17 AM   #4
Rewards Points: 5,336
I'd start be tracing the electric. Does the unit have both power and neutral hooked up?
Pull off the escutcheon plate at the ceiling to see if it's wired correctly to there.
Ron
Old 06-05-2011, 07:16 PM   #5
possibly the remote receiver mounted in the fan housing is overheating.
Otherbill is offline   Reply With Quote
Old 06-05-2011, 07:48 PM   #6
Would that mean it wouldn't work manually as well?
Old 06-05-2011, 07:53 PM   #7
Yes, because the receiver connects between the wiring coming from the switch/feed to the fan. If it is shot, the fan will not work.
Old 06-05-2011, 08:02 PM   #8
You can replace the receiver.
Ron
B. Franklin 1759
Old 06-05-2011, 08:16 PM   #9
How can I test or verify that the receiver is good or bad?
Old 06-05-2011, 09:23 PM   #10
Disconnect it and see if it works manually.
Ron
B. Franklin 1759
Old 06-06-2011, 12:11 AM   #11
Ok you guys are awesome I removed the receiver (a little black box) it had a black and white wire going in and a black, white and blue wire going out. So the fan works but the light portion does not. Did I miss something?
Old 06-06-2011, 12:43 AM   #12
Rewards Points: 512
Manually, the hook up would be black and blue together with the black coming in.
Old 06-06-2011, 06:20 PM   #13
The blue wire energizes the light.
Ron
B. Franklin 1759
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
