Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 12:34 PM   #1
Ceiling fan
I have a fan the lights dont work.There is voltage going to the lights.There were some flouresant lamps in and some of them had a very small touch of light and a pulse....they were going on and off.I changed them out to incandesant lamps and they don t work at all.
mick1966 is offline   Reply With Quote
Old 05-02-2011, 04:36 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
more info please
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-02-2011, 06:08 PM   #3
Rewards Points: 506
Bad bulbs?
jlmran is offline   Reply With Quote
Old 05-02-2011, 06:48 PM   #4
I've tried 8 lamps so its not the lamps.
Old 05-02-2011, 06:55 PM   #5
I dont know what else I can tell you.There is 120v going to all 4 lights on the fan.As I said with the flouresant lamps you can see a little light pulse
and nothing with the incandesant lamps.
Old 05-02-2011, 09:30 PM   #6
Rewards Points: 506
Where exactly are you measuring the light voltage? Maybe there is a failure downstream from where you are measuring. Maybe the contact at the bottom of the socket needs to be gently pryed up...with power off of course. Maybe the wiring is bad in the sockets. Just brainstorming.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
