Ceiling Box Support Rating - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 04:15 PM   #1
Ceiling box support rating
How can you determine the weight an existing ceiling box will support? Is the maximum weight that it can support imprinted on the inside of the box?
I have 2 chandeliers with weights of 10 lbs. and 13 lbs. I would like to use the existing boxes if possible.
Thank you,
Mike
Mike2401 is offline   Reply With Quote
Old 03-18-2010, 04:55 PM   #2
Solutions (handyman)
Rewards Points: 364
Mike, Not an electrician but did build my own house, including electrical. I would guess NO, unless you can see how the box is afixed to the trusses(rafters). If it, the box, is just screwed or nailed on one side, chances are that it would be limited as to what it can hold. (a light fixture is okay). If it is screwed up through the bottom (now the top) then there probably is a support piece of 2x4 between the two trusses, which would hold the weight. The box may hold the chandelier "as is", depending on the actual weight, but better to be safe than sorry. The box isn't the issue, it's how it is fastened to the ceiling framework.
Mark Harvey is offline   Reply With Quote
The Following User Says Thank You to Mark Harvey For This Useful Post:
Mike2401 (03-19-2010)
Old 03-18-2010, 07:14 PM   #3
Master Electrician
Rewards Points: 3,862
More than likely whatever boxes you have they will support an 11 or 13 pound fixture.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 10:14 AM
Support andFasten plywood panels to ceiling rok7751 General DIY Discussions 1 06-11-2009 06:22 AM
False ceiling... Why? jpelzer Building & Construction 3 06-03-2009 08:01 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
