Ceiling Box Help Pls. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 06:57 AM   #1
Rewards Points: 91
ceiling box help pls.
Hi:
I have four 14/2 cables going into a 1 1/2" deep light box. How many wires can you stuff into one extremely tiny box? I can't get four connected and in the box. Are there alternatives? I can't use a separate junction box. I want to bury everything in the ceiling.
Allthunbs is offline   Reply With Quote
Old 01-11-2013, 07:14 AM   #2
Rewards Points: 20
You must leave your box accessable you can't just bury everything in the ceiling. They do make deeper boxes than 1 1/2, try an electrical supply store.
daveb1 is offline   Reply With Quote
Old 01-11-2013, 08:47 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
A 4" x 1 1/2 octagon box is rated for 7 #14 conductors minus clamps, hickys and such. Can you switch the box and install a 4" x 2 1/8" box which is rated for 10 #14 conductors?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-11-2013, 08:53 AM   #4
Licensed electrician
Rewards Points: 1,264
I don't even think that box would be big enough. They count wire nuts as box fill in Canada.
Old 01-11-2013, 03:23 PM   #5
Rewards Points: 91
Thanks Dave:
Yup, that's why I'm trying to get all of the wiring in the box so as not to bury a junction box in the ceiling.
Old 01-11-2013, 03:25 PM   #6
Rewards Points: 91
Right on! Now, I'm having enough trouble getting 4x NMD90 in a 4" octagon 1 1/2" deep. How in tar nation does one get 7 in there????? Do they sell electrician's shoe horns :-)
Old 01-11-2013, 03:28 PM   #7
Rewards Points: 91
Hi Jim:
Thanks. I can certainly understand why wire nuts (Marettes, here) are counted as well. I can't even bend the wires in to get them into the box. I'm going to have to experiment with larges boxes.
Old 01-11-2013, 06:00 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
For this post I am going to assume that NMD is like our NM (romex).
When Electures states 7 #14's he doesn't mean 7 14/2's. Each current carrying conductor counts as one, then all the grounds count as a total of one.
So, in your case, 4 14/2's would actually be 9 #14's in that box.
You are overfilled by one cable.
Again, this is by NEC rules.
Old 01-11-2013, 11:39 PM   #9
joed's Avatar
Rewards Points: 11,998
And in Quebec you are NOT permitted to do your own electrical work. You must hire an electrician.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
