Ceiling Box Adapter? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 10:48 PM   #1
ceiling box adapter?
hey folks,
first, sorry for what's probably a very basic question.
I bought a ceiling lighting fixture, but the plate that attaches to the ceiling box is about half an inch wider than the box. is there some kind of adapter plate? I'm having a hard time finding anything.
thanks much.
jlberkeley is offline   Reply With Quote
Old 10-27-2010, 03:06 AM   #2
An adapter device, for enabling installation of an electrical light fixture to a ceiling mounted electrical box by one person, includes an opening into which a plurality of bendable tabs and a cover screw engaging yoke extend. The adapter device is affixed in an electrical access hole in the body of the electrical light fixture and enables the light fixture to be temporarily suspended from the partially unscrewed cover screw on the electrical box. The temporarily suspended light fixture may be readily aligned with adjacent walls, etc., rotated to enable installation of permanent support anchors, and repositioned to permanently secure it to the installed support anchors.
Jacks-Hon is offline   Reply With Quote
Old 10-27-2010, 09:01 AM   #3
Licensed electrician
Rewards Points: 1,242
The adapter plate is made to fit different size and shaped boxes. You should be able to find mounting holes that will work with your box.
Old 11-14-2010, 06:51 AM   #4
review this
Old 11-14-2010, 08:48 AM   #5
An old Tradesmen
Rewards Points: 6,498
Jack.
If your going to give aid help to our DIY members. You are allowed to have a link to your companies website in your sig.
No need to try and disguise it as a look as look at this install.
However. If you just want to advertise and not help DIYers. then you must pay for advertising.
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
