Ceil Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 01:14 AM   #1
Ceil fan
Does the blue and black wire go together or white and blue. And I hook it up to power and nothing worked. Then I disconnect but still got shocked. How??
gibsonc2 is offline   Reply With Quote
Old 12-19-2012, 01:25 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Fan has a light attached to it?
Black and blue from fan go to the black in the ceiling box.white to white,green to bare copper ( ground wire).
Shut off the breaker before attempting the above!
sublime2 is offline   Reply With Quote
Old 12-19-2012, 01:48 AM   #3
I'm wiring it in myself to a light switch. Will 18 gauge lighting wire work. I just hook it straight to light switch correct. Do I have to run a ground wire up to it. Thanks
Old 12-19-2012, 02:24 AM   #4
No!!!! Fire waiting to happen! 18 ga is nowhere near large enough. What size is the breaker for the circuit you are working on? If it's 15 amps, you need 14 AWG, if 20 amps, need 12 AWG wire
mterry is offline   Reply With Quote
Old 12-19-2012, 05:55 AM   #5
Rewards Points: 1,294
I am usually an advocate of "do it yourself", but it sounds like you are in way over your head. Please get someone in there that knows what they are doing to help you before someone gets seriously hurt. Your comment about getting shocked is of big concern to me.
danpik is offline   Reply With Quote
Old 12-19-2012, 07:53 AM   #6
Rewards Points: 85
My concerns exactky
JohnC20 is offline   Reply With Quote
Old 12-19-2012, 11:13 AM   #7
Special User
Rewards Points: 1,230
16ga blue wire? OP may not be in the US.
gibsonc2 where are you located?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
How to cut acrylic light diffuser panels theseeker Electrical 21 07-21-2014 06:01 AM
new install double switch ceil fan w/rheostat and seperate light Voyager 12 Electrical 5 01-10-2012 03:10 PM
