Cctv Drain Inspection System - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 01:43 PM   #1
cctv drain inspection system
Hi Contin here,
Had couple occasions with problem of block drain causing leak. Flat uses same drain stack hence when blocked causes leak down stairs.
Hence compensation costs was required. In order to avoid same problem in future considering the following project as never seen down drain and ? whether narrowing of drain somewhere, which clogs up easily.
As hiring and equipment exspensive, requiring ideas for diy to use some type of flexable electrical/optic cable and camera of normal kithen drain diameter pipe 1 & 1/2 inches.
Does anyone have ideas as to how to go about project and where to get equipment. Also can existing tv/computer screen be used to display image obtained.
Using plumbers spring after event a bit too late for prevention.
Thanks Contin.
contin is offline   Reply With Quote
Old 04-08-2010, 02:49 PM   #2
Rewards Points: 81
Yea milwaukee tools and extech tools make inspection cameras and they are waterproof. I like the milwaukee because you can add extensions to make the cable longer. They are around $300 or maybe a little more.
Chevyman30571 is offline   Reply With Quote
The Following User Says Thank You to Chevyman30571 For This Useful Post:
contin (04-16-2010)
Old 04-16-2010, 08:07 AM   #3
Thanks for the info.
Contin
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
