Caused A Short At Dimmer Switch - Now Lights Won't Turn On - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 12:30 PM   #1
Question
Caused a short at dimmer switch - now lights won't turn on
I'm finishing my basement and previously wired a 3-way switch that has been working fine. I went back to the switch to look at the wiring as a reference for another circuit I'm running and accidentally touched one of the poles with my screwdriver, and POW! - nice big spark. --yes, I know I should have turned off the power-- .
The 15amp circuit starts with a 3-way dimmer, then runs to a 3-way non-dimmer, then to 6 can-lights (running 60 watt bulbs).
To try and locate the problem, I've already done the following..
1) Checked the circuit breaker/panel. The CB didn't trip, but I re-set it for good measure anyway.
2) Checked both switches for power, and BOTH have current running to them, and current IS alternating between poles based on the position of the on/off switches. Obviously the circuit breaker/panel aren't the problem. This would also lead me to believe that the first switch (which I shorted with the screwdriver) is still functioning, and there doesn't seem to be a problem with the second switch.
3) I haven't yet checked to see if current is making it to the first can light (it was really late), but I did open the fixtures gang box and the wiring appears intact - I'm using plug nuts which obviously don't disconnect easily.
4) I plugged the bulb from the first can-light in the run to another fixture to test it and it's working fine.
Any ideas? Thanks in advance.
HighVolume is offline   Reply With Quote
Old 10-18-2011, 01:08 PM   #2
I would suspect you fried the dimmer switch.
Billy_Bob is offline   Reply With Quote
Old 10-18-2011, 01:23 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I am thinking the same thing get new dimmer.
The dimmer is allready toasted.
The dimmer can NOT handle the shortcircuit they will get damaged real quick.
Merci,
Marc
Old 10-18-2011, 02:42 PM   #4
liscenced electrician
Rewards Points: 538
I was thinking the same thing. Shorting a circuit on the load side of a dimmer switch will fry it every time
jimmy21 is offline   Reply With Quote
Old 10-18-2011, 03:27 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Sounds like we are all agree, fried dimmer.
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
switch on outlet strip causes lights to turn on for a second then go out johnnyd60 Electrical 12 09-22-2010 01:58 PM
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 02:31 PM
Dimmer Switch On other lights off. TonytheTiger12300 Electrical 5 12-23-2008 10:47 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
