Cattle Waterer 240V - Also Need 120v! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 04:02 PM   #1
Cattle waterer 240V - also need 120v!
I have a cattle waterer approx. 200' from the loadcenter in the barn. It is wired with 10/2 wg UF wire for a 240V internal heater. I need to install a 100W bulb inside of the waterer to keep the water lines from freezing in the winter. Is there any way that I can tap off the feed for 120V? I know you don't want the ground wire to have return power from the 120V line. Can I install a ground rod by the waterer for the neutral of the light, or maybe use a small subpanel? Thanks
2wheelinusa is offline   Reply With Quote
Old 10-05-2008, 04:05 PM   #2
Nope. Not safely.
Find a 240 volt source of heat.
Do NOT use a ground rod as a neutral. That's just a bad idea all the way around.
220/221 is offline   Reply With Quote
Old 10-05-2008, 04:14 PM   #3
Rewards Points: 562
Are you REAL sure thats 240 under there?? I have NEVER seen a 240 to a cattle waterer. Lucky to have 110. better check again. they sell 110 tank heaters at every farm store around,,,BUT there are alot of difference between a GOOD one and a cheapo. I have NO financial connection,just happy with there products,,,try this store for your heater needs,,,they work 300 % better and have MORE air flow around them www.hoskins-mfg.com All the cheapos are junk comparatively. forget the bulb idea,,,use one with a thermosat
4just1don is offline   Reply With Quote
Old 10-05-2008, 04:44 PM   #4
Rewards Points: 1,192
You could use a 240/120 volt xfmr to use a light bulb.
bobelectric is offline   Reply With Quote
Old 10-05-2008, 04:45 PM   #5
Idiot Emeritus
Rewards Points: 1,492
Instead of using a light bulb for heat, consider using heat tape.
If you get the self-regulating type, it comes in 120 and 240, and you can overlap it, leave it in open air, wet, etc. It cannot possibly overheat. It's pretty spendy, but you install it once, then forget about it. It doesn't need to be turned off during warm weather.
Rob
micromind is offline   Reply With Quote
Old 10-05-2008, 05:42 PM   #6
Rewards Points: 2,350
Others have made good suggestions, but an electrical supplier will be able to get you a 240 volt bulb that can be used in a regular socket, but you need a two pole thermostat or switch to turn it on or off.
Old 10-05-2008, 06:39 PM   #7
Just get a 240V bulb at a supply house - We use to use them for commercial Christmas lighting.
muckusmc is offline   Reply With Quote
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-23-2009 11:06 PM
30a 240v air compressor circuit crecore Electrical 2 09-21-2006 07:52 PM
240v electrical to unattached garage? alissakk Electrical 1 07-17-2006 04:58 PM
