CAT6 Brand Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 06:35 PM   #1
Rewards Points: 24
I have been looking at various CAT6 brands online. I found what seemed to be one that met all the recommended specs, however, not sure if the brand is OK. Does this look OK for residential use? Also it is CMR rated. I planned to run this in smurf tube through walls and ceiling. Wanted to make sure that was OK. Also, is there any issues if I also put my rg6 quad shield coaxial cable in the same smurf tube? I did not think so, but wanted to get feedback.
http://www.amazon.com/Shielded-Coppe...words=cat6+stp
jman2012 is offline   Reply With Quote
Old 10-08-2013, 06:50 PM   #2
Rewards Points: 6,652
Cheaper at monoprice http://www.monoprice.com/Category?c_id=102&cp_id=10234 A little cheaper at Parts-Express http://www.parts-express.com/cat/cat...t-6-cable/1607 Also Newegg is cheaper http://www.newegg.com/Product/Produc...=-1&isNodeId=1
Personally with Cat-5e still pretty cheap, and will handle everything that a homeowner will throw at it, you may be better off with Cat-5e, if cost is a issue.
Old 10-08-2013, 07:05 PM   #3
I ran all Cat 6 stuff from monoprice with no problems. Works well.
oatlord is offline   Reply With Quote
Old 10-08-2013, 07:30 PM   #4
Rewards Points: 24
Thanks for the quick replies. Cost is generally not an issue within reason. I looked at the Belden, however, that is too expensive. I was looking to get STP instead of UTP. Ideally I want CAT6, 23 awg, STP, solid, and in wall rated. My goal is to future proof as much within reason. We stream a lot of high definition TV. I could not find any brand information on the amazon.com bulk cable and generally had a hard time finding bulk cable online that met the specs above. Any help would be much appreciated.
Old 10-08-2013, 08:00 PM   #5
You could always send Ethernet-Cords a email, to find out what brand their bulk stuff is.
Old 10-08-2013, 09:32 PM   #6
Rewards Points: 24
Looks like it is Vertical Cable. Ever heard of them?
Old 10-08-2013, 11:13 PM   #7
They have been around since 1987. Now the question is, where is their product manufactured, and does it meet the correct ISO spec's., ISO 11801/2002.
Tags
brand , bulk , cat6 , rg6 , smurf
CAT6 Brand and Through metal conduit. jman2012 Electrical 17 10-06-2013 09:32 AM
Running Cat6 and romex in same holes Tonglebeak Electrical 16 07-15-2013 09:46 PM
Whole House CAT6 & COAX wiring. ATLChris Electrical 4 05-21-2013 02:40 PM
1958 Ranch Home, Full of Character - First Home, First Major Project Thadius856 Project Showcase 519 05-11-2013 09:43 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
