Cat5 - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 08:46 PM   #1
cat5
What is the easiest way to run CAT5 from the basement to 2nd floor office? The easiest way is just to lay it on the stairs and through the kitchen, but wife did not like that.
timchi29 is offline   Reply With Quote
Old 07-25-2009, 09:19 PM   #2
Laundry chute???
KeithM62948 is offline   Reply With Quote
Old 07-25-2009, 10:20 PM   #3
Rewards Points: 502
If you go with plenum wire, you can use an return or supply A/C duct.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 07-26-2009, 12:15 AM   #4
Rewards Points: 1,016
Don't know your application, but how about a wireless network?
Old 07-26-2009, 11:16 AM   #5
The vents aren't a option due to locaation and I have a wireless network know and the adapter just crapped out so I was looking at a cheap and easy fix. I think I found some old co-ax that goes from the attic to the basement and then from the attic to a wall plate that I am not using. I might use that as a pull string.
Old 07-26-2009, 11:19 AM   #6
Rewards Points: 204
You might, if you get lucky and it will pull out. Hope it works for you.
Old 07-26-2009, 11:22 AM   #7
Do you have CAT5 already?
If not I'd go with CAT6e
Old 07-26-2009, 09:50 PM   #8
DIYer
I'm still putting Cat5e on new drops.... Cat6 adds all kind of bend radius requirements and is more fragile... and both of them go gigabit just fine. And to be honest most home networks are limited by their internet connection anyway... how important is 10gbit+ local traffic going to be really? And how long before 10gbit is standard anyway? 10 years from now?
Gigs is offline   Reply With Quote
CSST Gas Line Lightning Strike and Electrical Issue duteberta Electrical 18 07-29-2009 05:01 PM
Can I run CAT5 thru the electrical RMC? BradG Electrical 13 04-03-2009 11:31 AM
Types of Cat 5 brokenknee PC Repairs & Upgrades 34 01-06-2009 03:10 PM
How to route cat5 & coax? radon Electrical 2 02-20-2008 02:49 PM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
