Cat 5e Network Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2007, 12:59 PM   #1
I have a friend that has two data ports, and wants to split them to data and voice. Two pairs for a phone system, and the other two pairs for the data. Which are the pairs used for data? Thanks
helpless handyman is offline   Reply With Quote
Old 07-31-2007, 01:05 PM   #2
Agent 000
SecretSquirrel's Avatar
CAT5/CAT5e require 8 conductors (4 pair).
See this wiring diagram.
SecretSquirrel is offline   Reply With Quote
Old 07-31-2007, 01:19 PM   #3
Actually, only two pairs are used out of the four pairs on a Cat 5e . I am just trying to find the exact pairs. I beleive they are 1,2,3,6, but just want to make sure.
Old 07-31-2007, 01:55 PM   #4
Agent 000
You're right... sorry about that. I always terminate them by the first method.
Try this wiring configuration.
Old 07-31-2007, 02:33 PM   #5
Post
Thanks Secret Squirrel, I found it as well:
http://pinouts.ru/Net/Ethernet10BaseT_pinout.shtml
I am assuming it will run at 100?
Old 07-31-2007, 02:58 PM   #6
Rewards Points: 150
Pin 1,2,3,6 are for ethernet and should work for 100 Mbps, though you may experience some cross talk if the other pairs are used for the phone, especially when you get ring voltage through...
The good thing is that with short runs, etc. you probably won't notice any issues...
slakker is offline   Reply With Quote
Old 08-01-2007, 01:18 PM   #7
Gigabit Ethernet does require all four pairs. It's not recommended to do what you're suggesting, but it's not a safety hazard. It probably won't cause a problem on a short run, but I wouldn't want to have my download interrupted when the phone rings.
Use 7 & 8 if you have to do it this way. Run another line if you can.
Beren is offline   Reply With Quote
Home Network Help Frank Networking 10 11-28-2008 02:59 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
