Cat 5 Cable Underground - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 02:33 PM   #1
I have a need to run some Cat 5 cable underground and because I am concerned about potentially needing to replace the cable it is my intention to run the cable in conduit. What I am not sure about is should I use underground direct bury Cat 5 cable in the conduit? My concern is that it will be wet in the conduit as all conduits are and my thoughts are that the underground cable would be better suited for the damp environment. What do you think?
regularguy is offline   Reply With Quote
Old 10-28-2011, 02:45 PM   #2
Rewards Points: 758
If it's something you want for long term, go with the outdoor rated Cat 5. If it's just temporary, then regular might get you by for a while.
I would use outdoor rated as you are right. Conduits do get wet.
AandPDan is offline   Reply With Quote
Old 10-28-2011, 02:47 PM   #3
liscenced electrician
Rewards Points: 538
You would probably be fine with regular cat5. Direct burial would be better though, if you never want to have to replace it. Would it be incredibly hard to replace if you ever had a problem?
jimmy21 is offline   Reply With Quote
Old 10-28-2011, 02:55 PM   #4
HDNewf's Avatar
Hey regularguy.
I would definitely use direct burial rated cable. The conduit will give added physical protection, but the UF cable is a must.
I hope this helps,
HDNewf.
HDNewf is offline   Reply With Quote
Old 10-28-2011, 04:41 PM   #5
Rewards Points: 6,652
Yes, for about six months, then you start seeing dropped packets, or no connection. The OP needs to use the flooded cat-5e, regardless if it is in conduit or not.
Running underground cable across my yard blue sky Electrical 11 12-31-2011 01:35 PM
Underground antenna cable from detached garage PaulTurner Electrical 4 04-07-2011 07:08 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Underground Cable Question Livewire78 Electrical 7 12-09-2009 12:15 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
