Carrier Air Handler / Heat Pump Electrical Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 11:51 AM   #1
carrier air handler / heat pump electrical requirements
Guys in the HVAC side told me to post this here as well
Im having a new system installed and to save some cash i have removed the old furnace and heat pump and im going to be doing the wiring from the breaker box to the new unit. The installer has given me power wiring documentation, however im not certain how to interpret what he wants. Can anyone tell me in "laymans terms" what size breakers and what gauge wires i should run? Here is the system being installed:
1-Carrier model FB4CNF036, “Comfort” air handler.
1-Carrier 15 KW electric heater package.
1-Carrier model FILCCAR20 media air cleaner.
1-Carrier model TP-PHP” thermostat and control wiring.
1- Carrier model 25HBC336A003, 3ton, up to 13 SEER, “Comfort” heat pump unit 1-New copper refrigerant tubing package to run from the new air handler to the new heat pump unit. This will also include a TXV refrigerant flow meter.
1-New 220 volt rain tight disconnect for the new heat pump.
This is the wiring document he provided me with:
Cysnake is offline   Reply With Quote
Old 05-17-2012, 12:27 PM   #2
Code05's Avatar
Rewards Points: 1,104
Any way to rescan and make it larger and more clear, the data is there-but I cannot read it.
If not we can do a google search and get it.
Code05 is offline   Reply With Quote
Old 05-17-2012, 12:28 PM   #3
Rewards Points: 6,652
It states on the plate of the equipment, Max Breaker size. Does not matter if the disconnect outside is a 50 amp or 60 amp disco, what matters is the breaker inside.
Old 05-17-2012, 12:37 PM   #4
Code05's Avatar
Unless the unit says MOCP is to be fuses only. Quite common.
Old 05-18-2012, 07:04 AM   #5
Cant seem to get it any bigger, I can email it to you if you let me know an address. Thanks for all your help!
Old 05-18-2012, 07:07 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Save it as a pdf.
Old 05-18-2012, 10:43 AM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Just to have enough power for the 15 kw heater you will need a 70 amp circuit. How large of an electric service do you have?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Help with a carrier 50 HX heat pump to tstat bmata12 HVAC 1 03-16-2012 09:08 PM
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 04:14 PM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
