Carlon 1 Gang New Work Shallow Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 09:57 PM   #1
Carlon 1 gang new work shallow box question
New to the chat room and looking for some help. I installed a new work 1 gang plastic shallow box that has a fold over cover for the left hand side of the box. So half the box is covered by this plastic snap cover that folds over and I'm putting a switch on the right half of the box. When I fix the drywall- can i cover the left half leaving with drywall only the switch exposed? It seems like how it's designed but it would be tough to get to junctions on the left side of the box and wanted to make sure this wasn't against code. Thanks for any help here.
duker is offline   Reply With Quote
Old 03-04-2012, 10:09 PM   #2
Master Electrician
Rewards Points: 3,684
Got a picture of this box?
brric is offline   Reply With Quote
Old 03-04-2012, 10:23 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
http://www.amazon.com/Carlon-B117RSW.../dp/B000LPTDVG
Is this what you are talking about?
If so, then yes, you can sheetrock over one side, but this is made as an old work box to be used in exsisting shhetrock.
How did you mount it?
The Following 2 Users Say Thank You to jbfan For This Useful Post:
brric (03-05-2012), plummen (03-04-2012)
Old 03-05-2012, 08:27 AM   #4
http://www.homedepot.com/buy/electri...ck-178456.html
Here's the link to the box I'm using. Nailed it into a stud
Old 03-05-2012, 08:53 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I have never seen that box but it is a kinda a new work version of the one JBFAN referenced. You can drywall over the (left) side.You can work on the wiring from the single gang side of the box. Leave enough slack in your wires.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Code05 (03-05-2012)
Old 03-05-2012, 08:57 AM   #6
Code05's Avatar
Rewards Points: 1,104
The box is fine, you can cover the left side with sheetrock.
You need to leave your wires and splices extra long to comply with the free wire rule.
300.14 Length of Free Conductors at Outlets, Junctions,
and Switch Points. At least 150 mm (6 in.) of free
conductor, measured from the point in the box where it
emerges from its raceway or cable sheath, shall be left at each
outlet, junction, and switch point for splices or the connection
of luminaires or devices. Where the opening to an outlet, junction,
or switch point is less than 200 mm (8 in.) in any dimension,
each conductor shall be long enough to extend at least
75 mm (3 in.) outside the opening.
Code05 is offline   Reply With Quote
Old 03-05-2012, 09:06 AM   #7
Code05's Avatar
RJ beat me to it.
Old 03-05-2012, 09:48 AM   #8
Awesome. Thanks for the thorough explanation!
Old 03-05-2012, 08:15 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Just don't laugh but the junciton box what Jbfan and Duker posted thier link what some case we can call them " Pregant box " some case we called " Knocked up box " those two word you may heard from time to time.
Merci,
Marc
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 01:33 PM
Duct Work Question xlr8tn HVAC 1 01-19-2008 10:02 AM
Question regarding soil makeup (will my soil amendment idea work?) joeyboy Landscaping & Lawn Care 5 06-30-2007 11:24 PM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 02:43 PM
Site work question Jonny Homefixer Building & Construction 6 11-02-2006 09:43 AM
