Carlon 1 gang new work shallow box question
New to the chat room and looking for some help. I installed a new work 1 gang plastic shallow box that has a fold over cover for the left hand side of the box. So half the box is covered by this plastic snap cover that folds over and I'm putting a switch on the right half of the box. When I fix the drywall- can i cover the left half leaving with drywall only the switch exposed? It seems like how it's designed but it would be tough to get to junctions on the left side of the box and wanted to make sure this wasn't against code. Thanks for any help here.
Got a picture of this box?
http://www.amazon.com/Carlon-B117RSW.../dp/B000LPTDVG
Is this what you are talking about? If so, then yes, you can sheetrock over one side, but this is made as an old work box to be used in exsisting shhetrock. How did you mount it? |
http://www.homedepot.com/buy/electri...ck-178456.html
Here's the link to the box I'm using. Nailed it into a stud |
You need to leave your wires and splices extra long to comply with the free wire rule. 300.14 Length of Free Conductors at Outlets, Junctions, and Switch Points. At least 150 mm (6 in.) of free conductor, measured from the point in the box where it emerges from its raceway or cable sheath, shall be left at each outlet, junction, and switch point for splices or the connection of luminaires or devices. Where the opening to an outlet, junction, or switch point is less than 200 mm (8 in.) in any dimension, each conductor shall be long enough to extend at least 75 mm (3 in.) outside the opening. |
RJ beat me to it.:thumbsup:
Awesome. Thanks for the thorough explanation!
Just don't laugh but the junciton box what Jbfan and Duker posted thier link what some case we can call them " Pregant box " some case we called " Knocked up box " those two word you may heard from time to time.
Merci, Marc |
| All times are GMT -4. The time now is 02:40 PM. |
