Car Audio 8ga Wire Vs. Standard Romex Style 8ga - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 11:55 AM   #1
Car Audio 8ga Wire vs. Standard Romex Style 8ga
What is the difference as far as real world usage between a 'car audio' cable (thick insulated, 100+ strands) in 8ga vs a Romex style 8ga wire?
I can't find any reason that I could not use it to hook up stuff at the house as it is more temperature, chemical and abrasion resistand...am I missing something?
hibbity is offline   Reply With Quote
Old 10-16-2011, 12:06 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Yes, it is NOT rated for the voltage, NOR is it rated for the application. Individual conductors must be used in conduit, "romex" is cable.
Individual conductors in a raceway MUST be rated for at least the system voltage.
Your mindset is not unique, but it IS flawed. Use the right material for the application.
See NEC 110.3
Speedy Petey is online now   Reply With Quote
Old 10-16-2011, 04:14 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,858
Car audio cable is definitely not more abrasion resistant or temperature resistant than THHN, NM, UF, USE, SER, or any other UL listed permanent wiring I can think of. It's only advantage is that it is more flexible and prettier. It is not designed for use in line-voltage applications.
mpoulton is offline   Reply With Quote
Old 10-17-2011, 01:22 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 820
mpoulton kind of hinted at it......
The main reason is vibration. Solid wire does not do 'well' in high vibration enviornments....subject to cracking. Whereas, stranded wire is much more flexible...and less likely to break under high vibration conditions.
The automobile is a very harsh environment for wiring and elctronics. If you look closely at automotive wiring, the insulation is typically thicker.
Monster Cables is the biggest rip off there is.....Gold plated contacts? Sorry....copper is a better conductor than Gold. The only advantage that Gold has over copper is oxidation.....if you have a gas tight connection then copper does just fine.....
Nickel Beryllium is actually a better contact material to use for low current signals.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
