Old 05-03-2009, 06:16 PM   #1
Capping wires from Garbage Disposal
I know some might think this a silly question but does it matter what type caps I use to terminate each wire when I cut the switch to the garbage disposal unit? Also what about the ground? Someone has already removed the unit and capped the wires already at the disposal end. Having installed light fixtures in my bathrooms I followed the directions to cap the wires. I'm pretty sure it doesn't make a difference but I just wanted to confirm with someone. Thanks so much for any help.
Maureen
Missmosey is offline   Reply With Quote
Old 05-03-2009, 06:31 PM   #2
dSilanskas's Avatar
If a wirenut fits than use it
dSilanskas is offline   Reply With Quote
Old 05-03-2009, 06:47 PM   #3
Thanks so much.
Old 05-03-2009, 07:23 PM   #4
Idiot Emeritus
Wirenuts are what just about any electrician would use.
No need to strip the insulation, just twist them on.
The ground doesn't need to be insulated at all.
Rob
micromind is offline   Reply With Quote
Old 05-03-2009, 07:29 PM   #5
Bigplanz's Avatar
Maureen
Whichever wirenut fits, but remember all circuits must terminate in a box even if they are just capped off. Picture 1: no. Picture 2: yes.
Bigplanz is offline   Reply With Quote
Old 05-03-2009, 07:38 PM   #6
Question
I had granite installed and am replacing all the electrical. I purchased extenders but they don't seem to be working. Since all the wires are covered up inside the receptacles do I need to use the extenders? The granite was cut too tight and is causing a real hassle in placing the extenders. I bought longer screws and it works fine but I was just concerned with the idea that there is nothing surrounding the outlet other than granite and the old box if I don't use the extenders. There is only a slight bit of particle board that shows through. Any thoughts would be appreciated
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
Garbage Disposal Dilemma (with pic) tommy potatoes Plumbing 13 03-23-2009 06:50 PM
replacing a gfci recetacle for a dishwasher and garbage disposal sarahzuno Electrical 12 01-21-2009 12:41 AM
GFCI and garbage disposal Jeremy Hillary Boob, PhD Electrical 2 11-28-2008 08:01 PM
garbage disposal and dishwasher power amakarevic Electrical 11 10-06-2008 07:35 PM
