Capping Off Live Lines. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 10:57 PM   #1
Capping off live lines.
Hey I am doing a little renovation in my home and I was wondering can I cap off a live housewireing line that used to power an outlet in my room?
here is a picture of what I have done. note this is only semi temporary I will have an electrition in to ad some proper lighting and outlets. but at this time I don't know when Ill be able to afford.
A small board will cover this up to finish the wall. I can't remove the wires completely because I don't poses the skill and it is used to power other outlets in a laundry room
Gaupo is offline   Reply With Quote
Old 02-15-2013, 11:07 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You will have to install a junction box and put a blank cover over it. You can't just cap live wires and leave them in the wall or ceiling.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-15-2013, 11:09 PM   #3
Missouri Bound's Avatar
I appreciate your honesty about your abilities. You can't just cap off a live line and cover it up. You need to disconnect it at the source. I cannot see your picture, but I will tell you what you can do. If the wire terminates in an electrical box, you can wire nut the wires and put a cover over the box. You cannot cover the box with anything, it needs to be accessible.
Do you want it your way or the right way?
Old 02-15-2013, 11:36 PM   #4
Mhm okay now the area where the wires are is a fairly tight space. They were connected to a box. I removed it when I took out a small divider wall.http://imageshack.us/photo/my-images...215224608.jpg/
Can I install the box here where the wires hang? I would like to re hook the to an outlet.
Old 02-15-2013, 11:38 PM   #5
And the measurement for the area the wires are in is the width of a 2x4 (from white exposed stud to exposed stud )
Old 02-16-2013, 08:01 AM   #6
Rewards Points: 13,446
Just use a box something like this.
http://www.bing.com/images/search?q=...lectedIndex=43
Use roofing nails to attach it so there's no hump when you rock over it.
Old 02-16-2013, 08:11 AM   #7
Licensed electrician
Rewards Points: 1,464
Does that box have the capacity for 5 wires plus the receptacle?
I like these boxes. You may need to shave the stud slightly.
http://www.smartboxinc.com/smartboxes.php
Old 02-16-2013, 09:16 AM   #8
Lic Elect/Inspector/CPO
With 5 conductors assuming (2) 14/2 romex that would be 10 cu inch needed. Add the outlet 4 cu inches, so the total is 14 cu inches . The box would have to have a volume of at least 14 cu inches.
Here is a table.
Here is a link to box fill chart.
http://www.informationdestination.ce...Box%20Fill.pdf
NJMarine is offline   Reply With Quote
Old 02-16-2013, 03:46 PM   #9
When I removed the old box the plugin had both wires attached to it. so one side had two black wires other two white. and both the grounds were attached in the same area. From school I don't remember an outlet like that. was that safe? or is each wire ment for its own outlet?
Old 02-16-2013, 04:07 PM   #10
All outlets are done that way.
It's so you can daisy from one outlet to the next.
The ground should have been pig tailed so there was only one wire under the screw.
Extending electrical lines approx 6' It's Me Electrical 1 03-03-2012 06:13 PM
Drain lines for Mini Splits dbargaehr HVAC 2 05-24-2011 01:02 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Grinding stump but how deep are gas and electric lines buried? jbk Landscaping & Lawn Care 1 08-02-2008 11:46 AM
