Cap Electrical Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 08:28 PM   #1
Cap electrical wire?
I'm pulling out old insulation and came across a wire just hanging that had power to it. The wire has been snipped, but the end is still exposed. There are four wires, one yellow and one black (both look to be 12 gauge plastic insulated). The other two are black and are smaller diameter and have an odd looking insulation over them. The yellow and black both have power, the two smaller black don't. They were all wrapped in a black casing. This is in the ceiling.
I was told to cap them. The caps I've used and saw at lowes say they are for 2 to 3 wires twisted together. How should I deal with the wires? Just use the caps, one cap per wire? Something else? There is space, I can stick them in a box and cap them. Of course, turn off circuit breaker and test for power when I do it.
oscarMadison is offline   Reply With Quote
Old 02-28-2009, 08:56 PM   #2
After turning off the power & verifying its off
I would cap each wire & then tape them all up
I would also try to figure out where they are coming from
Old 02-28-2009, 09:55 PM   #3
joed's Avatar
Rewards Points: 13,306
That is some odd sounding cable. I have never heard of a cable with that wire configuration. Could it be from an old satellite cable or TV antenna rotator? What voltage was on the wires?
You should try to track down the other end of this cable and disconnect it.
Old 03-01-2009, 10:29 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,.. They sell Smaller wirenuts,...
Small enough to twist onto single wires down to maybe 16ga...
SD's idea for Capping is what I'd start with,...
I like Joed's idea the Best though,...
Back trace 'em,+ Disconnect where it Starts, rather than where it Ends....
Old 03-01-2009, 10:53 AM   #5
Rewards Points: 204
And put them in a accessible box with cover. You can't just cap them off.
J. V. is online now   Reply With Quote
Old 03-01-2009, 09:26 PM   #6
Okay, when I found the wire I tested it with Greenlee voltage detector. Today I tested with my multi-meter and it appears to be no voltage tried several times. The wire looks like it was heading in the direction of the overhead light/fan. This light was rewired so I could turn it on and off with a wall switch. I was wrong on the color of the secondary wires, light brown.
I was able to trace back to the side wall and then it goes behind a collection of two by fours. It starts out hanging right below a box, where I found it. It follows several other wires including the one for the light switch. Right before it goes behind the two by fours it and the others are fastened to the two by fours, all side by side. It looks like it is comes out from behind the two by four and is cut off, basically not connected to anything. If this is the case it shouldn't show up on the voltage detector correct? Could the wires it is running alongside for awhile cause the voltage detector to give a positive?
Really bad photo of wire:
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
Self induced electrical problem :( domiflichi General DIY Discussions 7 07-10-2008 08:33 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
