Can't Tell Which Wires Is Hot Or Netural - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 04:42 PM   #1
can't tell which wires is hot or netural
Hello! I am trying to hook up this antique pendant lamp and the cord it comes with has only 2 wires inside. They are both smooth and white, no stripes or ridges to tell which one is hot or neutral. And what should I do with the third one coming out from the ceiling? Thanks in advance for your advice.
lawrencek is offline   Reply With Quote
Old 04-22-2012, 04:53 PM   #2
Sparky
Rewards Points: 510
using a continuity tester, the hot should be the 'button' in the bottom of the lampholder, and the neutral the outer shell. ground should go to the box or mounting bracket
Techy is offline   Reply With Quote
The Following 3 Users Say Thank You to Techy For This Useful Post:
Jeeps (04-22-2012), PaliBob (04-22-2012), zappa (04-23-2012)
Old 04-22-2012, 10:33 PM   #3
Is this third wire bare copper. If so, that is your ground and you can screw it to the box. The antique fixtures never had grounds so it's not needed. And for lighting without black or white wires, use a tester for determining the hot(black)
wire to the button.
Kurtiswm is offline   Reply With Quote
Old 04-23-2012, 05:46 AM   #4
Rewards Points: 1,298
Originally Posted by Kurtiswm View Post
And for lighting without black or white wires, doesn't matter what gets connected to what. Works either way.
Untill you accidently touch the exposed portion of the threaded socket...If that is wired to the hot side it makes a big difference
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
sirsparksalot (04-24-2012)
Old 04-23-2012, 06:14 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you want to get technical, you really shouldn't be installing the fixture unless it has a UL listing on it.
Old 04-24-2012, 12:33 AM   #6
Rewards Points: 512
Is this third wire bare copper. If so, that is your ground and you can screw it to the box. The antique fixtures never had grounds so it's not needed. And for lighting without black or white wires, doesn't matter what gets connected to what. Works either way.
Please don't post advice that is wrong. It DOES matter, even though it works.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
