Can't Tell If GFCI Installed - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2008, 08:49 PM   #1
can't tell if GFCI installed
Is there a way to tell if a GFCI is installed in the breaker? This duplex (as all the other duplexes on this street) was built in 1983 and I heard that GFCI outlets were enforced after 1960.
I don't see the 'test' and 'reset' button on any outlets nor do I see them on the breakers.
Should I assume that there are no GFCI protected circuits, or is it possible that some older GFCI breakers don't have the "test" button on them?
grgryl is offline   Reply With Quote
Old 08-05-2008, 09:04 PM   #2
If you're comfortable with electricity, hook a 7-1/2 bulb from hot [short slot] to ground [round hole] using a lamp socket with pigtail leads,
http://media.mydoitbest.com/imagereq...=C&newsize=200
in outlets near sinks.
Make sure the pigtail wires from your lamp socket actually make contact with the outlets internal contacts.
This simulates a ground fault. If the bulb stays on you are not protected.
Old 08-05-2008, 09:20 PM   #3
Rewards Points: 508
Send a message via AIM to theatretch85
Thats one way of doing it, or you can use a 3 light tester with the button on it (used for testing GFI's). This is usually the preferred method of testing GFI's. If there is a GFI and its good, pushing the button will trip the GFI. If the circuit is still live after pushing the button, then there is either no GFCI device or its faulty.
theatretch85 is offline   Reply With Quote
Old 08-05-2008, 09:32 PM   #4
Yes, buy this gadget!
It's safer and more accurate than my lamp method.
Old 08-05-2008, 09:38 PM   #5
Thanks! I'm looking at the Lowes and Home Depot website for this but can't find it. Where did you get that photo from? SHould I just ask for "Three light tester"?
Old 08-05-2008, 09:45 PM   #6
Rewards Points: 508
You can ask for a "GFCI plug in tester" but at any rate you should be able to find this at any home center in the electrical department. I just "google-image" searched for "GFCI tester" to find that picture. I have one that works wonders for properly testing GFCI's. You will likely see two types of the same thing, and one will probably be a little cheaper. Usually the cheaper one does not have the ability to test the GFI's (does not have the button) so make sure you get the right one. Other than the button they both do exactly the same thing.
Here's a link to a product at Home Depot made by Gardner Bender: http://www.homedepot.com/webapp/wcs/...d&ddkey=Search
Old 08-06-2008, 12:39 PM   #7
There are at least 32 ways to connect one, two, or three wires to the three terminals of an outlet, and only one is correct.
This gadget doesn't test everything but it goes a long way in that direction.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
Can a GFCI protected light be installed into a normal light circuit? boongywoongy Electrical 6 05-19-2008 08:02 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
