Old 12-29-2012, 06:20 PM   #1
Can't remove bathroom light fixture.
I'm trying to remove the light fixture in my bathroom but strangely see no way to remove it. There's nothing obvious about how to dismantle and remove it from the wall - no screws or anything to twist off. The only thing I see is a tiny hole on the stem of the fixture that looks like it may be a hex socket(depending on the light, it can look either hexagonal or circular). I've tried using a couple of hex keys but if it is in fact a hex socket its size in somewhere between 5/64 and 3/32 and I don't have anything in between those two. For some reason I'm skeptical that the tiny hole/socket is the key to dismantling the fixture, but I haven't seen any alternatives so far.
This is the fixture:
Close up:
The possible hex socket:
Closer view:
Behind the base(I tried messing the the nuts but that didn't get me anywhere and it's hard to do anything back there):
Has anyone ever worked with a light fixture like this or have an idea of how to get it off of the wall?
notreallyme is offline   Reply With Quote
Old 12-29-2012, 06:47 PM   #2
Mad Scientist
You should be able to unscrew the fixture from it's bracket, just twist the whole thing counterclockwise. Do you have any intention of saving this fixture? Personally, I'd just smack it with the big hammer until it's down.
If you want to save it, remove that tiny allen screw and see if that brass piece moves. My guess would be that the brass piece slides back, then the cover piece can be pulled back, then the two nuts can be loosened so they're not jammed together, and then the threaded nipple oughta unscrew.
But like I said, if that sounds like too much screwing around, I haven't yet encountered a light fixture that can't be removed with a large hammer...
McSteve is offline   Reply With Quote
Old 12-29-2012, 06:57 PM   #3
Your last picture shows to nuts behind the plate on a threaded rod. Loosen the two nuts as one is acting as a locking nut this will help you unscrew the rod out, be careful as there are wires in the tube which will twist. Then you will have enough room to unscrew the back pate and expose the wires to remove them. Please have your power to that light turned off.
epson is offline   Reply With Quote
Old 12-29-2012, 07:20 PM   #4
It's a metric set screw.
Old 12-29-2012, 07:38 PM   #5
Super Moderator
Joe has it-----
remove the set screw--
slide the collar forward--
slide the escutcheon --forward---
use a stubby screw driver to remove the screws holding the unit to the box.
Old 12-29-2012, 07:40 PM   #6
Mad Scientist
Ah dang, somehow the simple "just unscrew the bracket" solution slipped my mind. Guess I'm getting too used to just using the big hammer
Old 12-29-2012, 07:51 PM   #7
Super Moderator
If I were doing it--the instructions would have been--
Chuck a hacksaw blade into the Sawsall---cut off the tube and retaining ring --
Old 12-29-2012, 07:54 PM   #8
Did you shut the power off first?
Old 12-29-2012, 07:59 PM   #9
Electrical Contractor
Auto power off when the blades make contact!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 12-29-2012, 08:03 PM   #10
Yeah lots of smoke and your hair gets a new perm.
Old 12-29-2012, 08:13 PM   #11
Super Moderator
Real men don't worry about switches--
Old 12-29-2012, 08:14 PM   #12
been there done that...
Old 12-30-2012, 01:10 AM   #13
Will this help ?
dmxtothemax is offline   Reply With Quote
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 10:06 PM
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 07:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
