Can't Install Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 04:18 PM   #1
Can't install Breaker
I have a Murray LC008DS load center that I am trying to install a gfi breaker into, but I can't for the life of be get the breaker installed.
Here is the breaker
http://www.amazon.com/Murray-MP120GF.../dp/B000BQYJLY
And here is a picture of the panel.
I just can't get the breaker to tilt into place, I have tried stating on the buss bar as well as the "retainer". I think these little tabs (see red arrows) are preventing me from getting the bottom of the breaker fully into place.
Do I just have the wrong breaker, or am I missing something? It's a Murray panel and Murray breaker.
John
npn_ is offline   Reply With Quote
Old 05-26-2012, 05:18 PM   #2
Rewards Points: 734
On the door to the panel there should be a label that lists applicable breakers for that panel.
From what I can see, it looks like its an older panel.
AandPDan is offline   Reply With Quote
Old 05-26-2012, 05:24 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Pull the next breaker out and take another picture... that may be some type of limit from the manufacture to impede a breaker being installed...
Old 05-26-2012, 05:26 PM   #4
E2 Electrician
The door of the panel probably says, "Do not twist out, No breaker intended" lol....
Old 05-26-2012, 05:27 PM   #5
Here is part of the label from the door. This load center is in an outside building (pool fiter house) Note the MP type.
Old 05-26-2012, 05:32 PM   #6
There are only 2 breakers in the panel, all the others look identical (at least the slots that don't have a breaker in them) The slot that I am trying to install into had a breaker in it at one point, but I think it may have looked a little different - i don't have it any more.
Old 05-26-2012, 05:34 PM   #7
E2 Electrician
So take the next breaker out and compare the bottom slot and see what gives...
Old 05-26-2012, 05:35 PM   #8
Rewards Points: 734
I can't open your pic of the label.
You can move that existing GFCI breaker over. See if it fits. Check the model when you do.
Old 05-26-2012, 06:13 PM   #9
Taking out the existing breaker yielded some interesting info. For one it's not a murray breaker, it says BRYANT Type BR. I thought you were not supposed to use breakers that are not made by the same manufacturer as the load center?
In addition to that, there are some physical differences as well.
Here is a picture of the existing circuit breaker(right) and the one I am trying to add. They are different, but also similar. The yellow area on the left is set back so that is not an issue. The one on the right has a notch on the bottom but also has a shorter slot on the top, so the distance from the "bottom" of the breaker to the bottom of the "slot" looks to be about the same.
Old 05-26-2012, 06:41 PM   #10
E2 Electrician
Guess you know what you need to do then...
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
proper way to install TWO breaker boxes. Cinci Joe Electrical 1 04-27-2011 10:18 PM
Heat Pump trips breaker gt1935 HVAC 2 03-26-2011 11:06 PM
240V/30A outlet install with 1/2" 2 pole breaker neal0713 Electrical 5 02-03-2011 11:35 AM
