Can't Get New Bulb To Go Into Puck Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 10:18 AM   #1
Can't get new bulb to go into Puck Light
Hi, I am trying to replace the bulb on my under cabinet puck light. I removed the old bulb easily, but the new one will not slide into the holes. I broke one bulb trying to force it in, and just bought another one (and at $6 each, I don't want to break another one!). I don't know why it won't slide in. Any advice?
teacherfixer is offline   Reply With Quote
Old 03-25-2012, 10:28 AM   #2
Licensed electrician
Rewards Points: 1,266
Check to see if the blades in the socket are jammed together. Sometimes the bulb get inserted on the outside of the blades instead of between.
Old 03-25-2012, 11:08 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Do you have the correct bulb?
Coastal South Carolina
How to install an outlet to a light bulb fixture. enforcefx Electrical 2 10-17-2011 09:08 AM
Light bulb in fan goes off and on ilyaz Electrical 2 07-19-2010 10:00 PM
Light Bulb Burst Mark Harvey Electrical 4 02-20-2010 01:54 PM
Question about light bulb burnout arc mothra Electrical 5 04-20-2009 02:02 PM
Flourecent light bulb question shadango Electrical 7 06-28-2008 09:28 PM
