Cant Figure Out Why The Outlet Wont Work - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 09:32 PM   #1
cant figure out why the outlet wont work
OK, I have an outlet that has gone out and the rest of the outlets on that line. However, the first outlet still works because when I turn off the breaker for that line the first outlet is working.
I have tried replacing the outlets on both sides of the wall, outside and inside and still its not working and theres no electricity coming from the wires inside the wall.
The problem seems to be somewhere between the first 2 outlets, however I feel sure that its coming from that second outlet because it has been faulty for a while, had to jiggle the plug to get it to work at times, plus that outlet would get overloaded and throw the breaker off. However the wires coming from within the wall seem solid and doesnt seem as though its coming from there, plus as I said before theres no electricity there when I test the wires.
Baffled.
jamjar is offline   Reply With Quote
Old 09-13-2009, 09:38 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Check the wires at the first receptacle.
As you have found replacing the others, it contains 2 sets of wires.
Old 09-13-2009, 09:49 PM   #3
thanks
Thats a good point, I'll try that.
Old 09-14-2009, 07:43 AM   #4
joed's Avatar
Rewards Points: 13,716
The problem could be in the working receptacle. Have you checked that?
If the wires are plugged into the pushin/back stab holes move them to the screws. Back stabs are a very common cause of this type of problem.
Old 09-14-2009, 01:00 PM   #5
thanks you guys
JBFAN,
That was the problem, thank you very much, and to joed also.
Old 09-14-2009, 04:28 PM   #6
jbfan's Avatar
Rewards Points: 650
Originally Posted by jamjar View Post
JBFAN,
It is nice to see that I know what I'am talking about!
Old 09-16-2009, 02:17 PM   #7
jbfan
Lol lol
Only one outlet will power treadmill? archer75 Electrical 17 05-05-2009 12:20 AM
No power in outlet sherben2 Electrical 16 03-19-2009 11:35 AM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
loose outlet boxes on metal studs windowguy Electrical 7 01-29-2009 12:12 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
