Can't Figure Out This Doorbell Problem!! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 05:04 PM   #1
Unhappy
Can't figure out this doorbell problem!!
My doorbell stopped working about 6 mo ago. I finally got around to fixing it.
I checked the wires at the button with a multimeter... I have voltage there. Connected the 2 wires... no bell. Check the bell... I have voltage there. Replace the bell, no change. Touched a 9v battery to both bells (new and old) they both work. Checked the transformer... i have voltage there. I also checked continuity throughout the system and no problem.
Do I have a short?
dontstop611 is offline   Reply With Quote
Old 12-02-2008, 06:19 PM   #2
biggles's Avatar
remove the bell wires tie them together remove the secondary on the TR and put your meter in AUDIBLE /OHMS on the 2 wires off the TR..... have somebody push the button should see or hear something if the circuit is complete.
Old 12-02-2008, 06:33 PM   #3
Rewards Points: 894
How many wires do you have leaving the transformer, and how many at the bell?
is there a back door button and a second bell/chime for that door?
What is the voltage at the transformer?
Try having someone else push the button while you measure the voltage at the transformer.
When you measured the voltage at the button, was it disconnected, or still in the circuit?
Ultrarunner2017 is offline   Reply With Quote
Old 12-03-2008, 01:21 PM   #4
BIGGLES,
I tied the bell wires and button wires together I removed the secondary at the transformer. I have continuity throughout.
I didn't have a 2nd person to press the button so I tied them together. I checked the continuity of the button by itself, and it was good.
Thanks for the reply.
Please continue to help me troubleshoot this problem.
Old 12-03-2008, 01:29 PM   #5
KE2KB,
I have 2 wires leaving the transformer - both red. I have 2 at the bell - red and white. I have 2 wires at the button - red and white. There is no back door bell. The white wires are tied together with a wire nut near the transformer.
The voltage at the transformer was 0.73 volts. I checked it four times, both red to ground and black to ground.
The voltage at the chime 0.65 volts. Again, both red and black to ground.
The button 0.63 volts.
The transformer is bad... isn't it?
Old 12-03-2008, 03:24 PM   #6
If you measure the open circuit voltage of the transformer secondary and it doesn't show ~18v or ~27v, with the primary winding powered by 120v, then it's bad.
Old 12-03-2008, 05:26 PM   #7
biggles's Avatar
TRs are usually 10Vs solid with nothing connected
Old 12-03-2008, 05:44 PM   #8
electrical contractor
Rewards Points: 150
Bad transformer. Secondary voltage could be anywhere between 10 and 24 volts, depending on your chime, should be marked on the transformer.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 12-03-2008, 07:31 PM   #9
biggles's Avatar
if your door TR is down on the CB panel in the basement,and the 10Vs is run up to the switch then the bell the VA(voltamps) rating on it is the part that takes the hit with nothing working.that is why the bell works when you test it right at the TR
Old 12-08-2008, 11:35 AM   #10
Rewards Points: 894
With only 0.65V on the transformer, either it is bad, or there is no 120V powering it.
You need to make sure you have 120V on the primary before you replace it.
Old 12-08-2008, 04:55 PM   #11
Rewards Points: 1,514
On the low voltage (bell wires; secondary) side of this transformer, you mentioned red to ground and black to ground. Did you mean red to red?
On some systems, low voltage hot to ground means nothing. The important voltage measurements are across the two terminals on the bell and across the two low voltage terminals on this transformer. On the high voltage side (primary here; usually with pigtails instead of screw terminals) see that you have 110 to 120 volts.
Some bell transformers have more than two secondary terminals to give a choice of voltages such as 10, 16, 24, 32, etc.
Old 12-09-2008, 03:38 PM   #12
Rewards Points: 894
Uh Oh; I'm afraid he is measuring from each transformer terminal to ground, not between terminals. I think the red to ground and black to ground refer to the meter lead colors.
You need to be in the AC Volts mode, and it doesn't make a difference which meter wire goes to which terminal, just that you need to measure between terminals of the transformer, not between one terminal and ground.
Ground is not normally part of the doorbell circuit.
Doorbell wiring problem schulte24 Electrical 9 08-28-2008 08:40 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Doorbell Problem TonyD Electrical 5 03-23-2007 09:04 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
