Old 10-11-2012, 09:16 PM   #1
Ge0ff
Cannot turn MAIN trip back on
Hi Folks. Rewiring kitchen today. Had main turned off. When I finished I couldn't hit the main trip switch back on. So I disconnected the first receptacle in the circuit but the main would not go back on. Any ideas?
Ge0ff is offline   Reply With Quote
Old 10-11-2012, 09:17 PM   #2
Pure Genius
Is it tripping or will it not reset. How old? what brand?
Dierte is offline   Reply With Quote
The Following User Says Thank You to Dierte For This Useful Post:
Ge0ff (10-12-2012)
Old 10-11-2012, 09:24 PM   #3
Ge0ff
It will not reset. Offhand I don't know the make but it is pretty new.
Old 10-11-2012, 09:32 PM   #4
Electrical Contractor
Sometime when you turn a breaker off, it will go to the mid position.
Turn it off, then back on.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Ge0ff (10-12-2012)
Old 10-11-2012, 09:36 PM   #5
kbsparky's Avatar
and sometimes, the main is just plain bad.
Had that happen to me once, installed a new circuit into a Bulldog panel -- then the main would NOT turn back on. This was the last call of the day, at 4:00 PM.
Ended up having to do an emergency panel replacement, and didn't get finished until after 10 PM
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Ge0ff (10-12-2012)
Old 10-11-2012, 09:38 PM   #6
Ge0ff
Yes, I tried turning it completely off (it was) but no joy!
Old 10-11-2012, 09:39 PM   #7
Is this the main house breaker or the breaker for the circuit you rewired? If it is the whole house main breaker, turn off all branch circuits the try the main. When it holds, then turn on all the branch circuits
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Ge0ff (10-12-2012)
Old 10-11-2012, 10:00 PM   #8
DIY Enthusiast
sublime2's Avatar
Originally Posted by danpik
Is this the main house breaker or the breaker for the circuit you rewired? If it is the whole house main breaker, turn off all branch circuits the try the main. If/When it holds, then turn on all the branch circuits
Ftfy.=fixed that for you.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Ge0ff (10-12-2012)
Old 10-12-2012, 08:08 AM   #9
Ge0ff
Yes, I had turned off all the subsidiary breakers and still the main wouldn't budge ......... so I guess there is the problem. Will take another look this morning and if no burst of inspiration comes, I'll call in a Sparks. Will inform ye of the outcome.
Brought home all my power tool batteries last night and charged them but it's very overcast/dark this morning ............ so I guess an early weekend
Old 10-12-2012, 08:32 AM   #10
Sounds like the Main Breaker is stuck off, not tripping.
Sometimes they can be a PITA to reset. Push harder, may need replaced, the joy of things.
Cover the lugs so you cannot slip and hit them (this would be bad)
Gac66610 is offline   Reply With Quote
Old 11-29-2012, 12:24 PM   #11
Ge0ff
Got a Sparky to have a look ......... it was stuck and I didn't push it hard enough. Thanks for all the replies.
Why did my breaker not trip? Need some assistance on this one. Blackie_ Electrical 27 12-22-2011 08:00 AM
Electronic Air Cleaner Won't Turn Back On sweaty HVAC 1 07-04-2010 09:56 AM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
